Results 1 to 10 of 10
  1. I recently purchased the DVD The Bridge on the River Kwai. The DVD says it is 168 mins long but there is only one DVD. When I open up the DVD it shows 121 mins. What am I missing here? The box came sealed with one disc.
    canada
    You probably bought a bad copy from ebay or just missing the last disc,go to where you bought and ask for another one.
  3. The long time probably refers to the Bridge on the River Kwai (Two-Disc Collector's Edition).. you must have gtton a normal movie disk version .. or there might be a menu of extra videos accounting for the 47 minutes ... like making.. or deleted scenes..
    Or yours could be a edited version to fit a 2 hour version like they use on tv
    Oct 2005
    666th portal
    you don't have a real dvd. did you buy it cheap somewhere? probably recorded off of an edited tv broadcast. the actual movie details.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What are you using to "open the disc"?
    It's a single disc release for the standard and collectors edition, with the runtime listed as 167 minutes.
    Aspect Ratio: 2.55:1
    Number of discs: 1
    Rated:
    PG
    Parental Guidance Suggested
    Studio: Sony Pictures Home Entertainment
    DVD Release Date: November 21, 2000
    Run Time: 167 minutes
    Google is your Friend
  6. Member DB83's Avatar
    Jul 2007
    I have the UK version of the 2 disk edition. The box states the runtime of the feature as 155 minutes. Guess the lower time is due to PAL speedup.
    But I just had a thought. Id your disk pressed or burnt ? You have not read that 120 minutes on the physical disk without actually playing it ?
    Feb 2006
    wonder if it is one of those flipper discs. where the movie is on both sides of the disc.
  8. Member DB83's Avatar
    Jul 2007
    Originally Posted by Bernix View Post
    Whoever created that webpage requires a new watch. Whilst there may exist such a version no cinema site worth its salt should make such a glaring mistake.
    Have we heard from the OP since the first post ?
    I would like to understand where he obtained this disk.
