I have some DVDs that have no subs. I have ripped them as MKV files to my hard drive and added subs I've found on the internet. Now I want to combine mult discs' programming into one BD. I am using multiAVCHD which does seem to work fine. The problem is with the menus. When I first put the disc in my Panasonic player, the main menu comes up, and I can navigate to titles, chapters, turn on subtitles, etc. The problem is that once I select a title, and it is playing, I can't get back to the main menu. Neither the "top menu" or "pop up menu" which are the two options on my Panasonic remote, returns me to the menu.
I can use a work around, which is to us the "sub menu" button on my remote which then gives me several options, and if I scroll down to "top menu" and press enter, it returns me to the main menu.
I have no idea what is going on or why this is a problem.
I know there have been issues with Panasonic players, but I thought that was only for DVD-5's or 9's authored as BD discs which wouldn't play, and you have to use "strict AVCHD" for those. These are BD-R discs, which I didn't think was a problem. As I said, I can watch the discs fine. It is getting back to the main menu that's a problem.
Any help is appreciated.
SMK
Results 1 to 1 of 1
multiAVCHD create menu
By Miro72 in forum Authoring (Blu-ray)Replies: 0Last Post: 30th Aug 2016, 10:18 -
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 17:18 -
MultiAvchd menu problems
By Rael44 in forum Video ConversionReplies: 2Last Post: 10th Feb 2014, 05:08 -
multiAVCHD menu problem
By Clydesdale in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2013, 22:36 -
MultiAVCHD Chapter Menu Distorted
By reyflores in forum Authoring (Blu-ray)Replies: 0Last Post: 18th Mar 2013, 19:37
