  1. Member gunne's Avatar
    Sep 2017
    Denmark
    Hi Forum members,
    I'm using Handbrake to burn in subtitles from a srt-file to a mp4 file.
    For some unknown reason the first half a minute (39 seconds to be precise) of the text is missing on the encoded movie, but the rest of the film shows the subs just fine. The characters looks good, too, so it's not an overall code problem.
    I've been checking the srt file for errors, but I cannot find any.
    Do you have any similar problems, and did you find a solution?
    I look forward to hearing from you.
    BR Gunne
  2. Rename subtitle file to subtitle.srt
    and upload file to the forum(upload files button)
    to check if subtitle is ok
  3. Member gunne's Avatar
    Sep 2017
    Denmark
    Thanks roma-turok,
    I have uploaded the file, but I'm not sure where it went!
  4. Did you get the subs from a source saying second of 2 cds ?
  5. checking the srt file for errors
    Did you try Subtitle Edit -> Tool -> Fix common errors ?
    Perhaps "Go advanced" and paste the first lines as Code
  6. Originally Posted by gunne View Post
    Thanks roma-turok,
    Problem solved
    If next time on another movie you have same problem
    upload subtitles
  7. Originally Posted by gunne View Post
    Thanks roma-turok,
    You trying to tell me
    that you have problem upload file?
