Hi there!
I was wondering if anyone could please help me with a problem I am having when converting a video.
I'm using HD Video Converter Factory Pro to convert some Japanese shows I have from 720p to 1080p. It takes about two hours to finish, and it does work, only problem that I am having is for some reason, there is Japanese commentary playing over the actual audio from the show. I've played with all of the settings they have like when it comes to audio there's a Japanese (LC), 48000 option or Language 3. I'm not sure what those mean, but I've tried choosing both, and I still get the commentary over the actual audio. Then there's a section with the letter T on it, and the options are Disabled, Main 0, or add subtitle. I feel a bit dense, but I really don't know what I'm doing wrong, and if anyone can help me, I would greatly appreciate it.
Please and thank you!
Take a look at the original file with MediaInfo and post the results here in text format. MI does a decent job of showing all audio tracks.
Sounds like your program chose the wrong audio track.
I've never used your converter program, but there are other programs that might do a better job.
Also not sure why you would want to upconvert the video. Players seem to normally do a better job of that.
But others here may have a better suggestion.
And welcome to our forums.
Thanks for the warm welcome, redwudz!
I just like to have it a 1080p, so I can zoom in half way and still have a pretty big and decent frame. It's a just a personal preference, I guess.
Also, is this info you were asking for? Thanks again for your nice welcome, and help.
General
Unique ID : 235743677040764027192188631588248583910 (0xB15A94A787325085AFFF8AEC1CD97EE6)
Complete name : F:\スーパー戦隊\36. 特命\1-50\01. 特命戦隊、集結せよ!.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 432 MiB
Duration : 24 min 40 s
Overall bit rate : 2 448 kb/s
Encoded date : UTC 2014-06-20 08:29:44
Writing application : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:23:38
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Attachments : ahronbd.ttf / calibri.ttf / calibrib.ttf / calibrii.ttf / Eurosti.TTF / segoeui.ttf / segoeuib.ttf
Video
Format : AVC
Format profile : High 10@L5
Format settings : CABAC / 16 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Writing library : x264 core 140 r2377+16 [x86_64 10bit-depth]
Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=22.0000 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio #1
Format : AAC
Format profile : LC
Codec ID : A_AAC-2
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Title : Main
Language : Japanese
Default : Yes
Forced : No
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC-2
Video conversion stretched
By Anonymous in forum Video ConversionReplies: 19Last Post: 13th Jul 2017, 11:38 -
Video conversion causes timeline change in video players?
By jaybird in forum Video ConversionReplies: 18Last Post: 2nd Apr 2015, 18:01 -
Using madVr for video conversion
By marxzei in forum Video ConversionReplies: 0Last Post: 1st Apr 2014, 14:01 -
Video Conversion
By huckfinndy in forum MacReplies: 4Last Post: 25th Jan 2014, 21:22 -
iWisoft Video Conversion Help
By softfang in forum Video ConversionReplies: 3Last Post: 20th Feb 2013, 10:41
