Hi,
All of the sudden, I cannot burn or the burning takes over an hour to burn a Data DVD disk! I've tried on different devices, using the burner Ashampoo, and have used two different disks, still it'll either take over an hour or won't burn at all.
What can be the problem?
I'm using Windows XP Pro. Dell. Always usedAshampoo burning program, not had a problem, and have used same disk brands, Aone and TDK - no problems with these.
Also when I put in a blank DVD disk, it makes loud noise! As if the computer is going to.blow up.
Regards.
That's an old burner that you got..........Might be time to get a new one.
Movie Edit Pro 2015; issues burning Blu-Ray; errNo 5
By Steelerfan43240 in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Oct 2015, 23:49 -
Major MTS file issues- please help
By sb687 in forum Newbie / General discussionsReplies: 4Last Post: 13th Dec 2014, 14:51 -
LG GH24NSBO Burning Issues
By the_ghostly_one in forum DVD & Blu-ray WritersReplies: 9Last Post: 16th Jun 2014, 10:42 -
Issues with burning using ConvertxtoDVD
By acobbuga2 in forum Video ConversionReplies: 1Last Post: 1st Jun 2014, 04:11 -
MAJOR color correction help!
By Dr.Who in forum RestorationReplies: 0Last Post: 10th Oct 2013, 15:44
