I am completely new to this whole thing. I have season 1-9 of Dragon Ball Z all in BluRay and wanted to rip the discs. Can someone please direct me to the proper thread to rip these discs, how to remove the copyright protection and everything else that I need to know?
The chances are good that DVDFab HD Decrypter can decrypt your Blu-Rays to the hard drive.
There are guides to its use on that page. It's free for decrypting (ripping), trialware for conversion. -
Will there be a loss in quality? Also, do you know once the discs are ripped can they be tracked back to me?
Don't share the ripped copies. But otherwise no, there is no way to connect you to the copies you make.
MakeMKV is another free program for ripping Blu-ray. In its normal configuration, it will rip to mkv files, but if you start in Backup mode, the entire disc is copied to the hard drive. Once there you can convert to other formats if you like. -
Help in backup original Bluray discs
By cccf25 in forum Blu-ray RippingReplies: 14Last Post: 7th Aug 2016, 15:55 -
Bluray discs won't play, but DVDs will.
By WebFixer in forum DVD & Blu-ray PlayersReplies: 11Last Post: 6th Aug 2016, 09:00 -
Bluray players not compatible with MutliAVCHD Bluray discs
By VideoFanatic in forum Authoring (Blu-ray)Replies: 3Last Post: 29th Aug 2013, 14:59 -
Video Rip Bluray?
By monkeyeater in forum Blu-ray RippingReplies: 3Last Post: 16th Mar 2013, 06:51 -
Can Bluray players play TS h264 (ac3) Data Discs?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 16Last Post: 25th Dec 2012, 11:49
