I am trying to RIP an episode from a DVD but I cannot seem to remove the commentary on this particular episode. I am using Aiseesoft version 7.1.12. Any ideas?
I've not used that software. All of the software that I've used, you were able to select the audio track before the RIP.
If that software isn't allowing you to choose, you could simply removing it after.Google is your Friend -
Search "Rip DVD main movie", you will find many programs support this function. By copying main DVD title only, you can remove the unnecessary portions, including advertisement mentioned above, opening theme song, ending song, NG and tidbits, etc. Then use the built-in editor to trim the movie clips you want.
You could use the free program MakeMKV and simply select what you want - you end up with a mkv file the same size as the original. No re-encoding and quick.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Same thing here. Before I've concentrated on blu rays I've been using DVDShrink with DVDs. Usually together with AnyDVD. That way it has been possible to select what you want in a very flexible way.
But: I remember that some weeks ago somebody has opened a thread here about problems with DVDShrink after a version update of Win 10. -
How to remove audio commentary when burning & editing a decrypted DVD?
By Criswell in forum EditingReplies: 4Last Post: 28th Jun 2015, 20:54 -
DVD SHRINK How to remove audio commentary when burning?
By Criswell in forum DVD RippingReplies: 1Last Post: 27th Jun 2015, 21:03 -
DVD Ripper Needed to take commentary out
By RBCC in forum DVD RippingReplies: 11Last Post: 18th Jun 2014, 18:48 -
More Problems with ripping take out commentary
By RBCC in forum DVD RippingReplies: 7Last Post: 11th Jun 2014, 08:21 -
Merging Directors Commentary DVD to BluRay MKV Audio out of Sync
By v1nce in forum AudioReplies: 9Last Post: 21st Jul 2013, 05:20
