Hello,
is it possible to set the condition in ffdshow, for IPTV item - name or address? I mean, when I switch the item/IPTV channel in PotPlayer playlist, ffdshow condition "A" should be loaded, the same as with the video file name.
The names and path:
"STV1 (HD)" (File Name in Tab info)
"STV1 HD - PotPlayer" (name of sub-item in Task Manager)
rtp://@262.262.68.86:5004
"STV1 (HD).m3u8" (m3u8 name with just one channel for testing)
I tried to add these for the ffdshow conditions:
"on movie file name match with preset name"
"on movie file name match (with wildcards)"
"on application exe file name match" (I tried to use "PotPlayerMini64.exe /rtp://@262.262.68.86:5004")
"on volume name match"
It works with the video file name, recorded from TV tuner, for example:
"*Jednotka HD*.ts;*Dvojka HD*.ts"
Thank you in advance for any help, hint...
Finally I found something!
It works with IPTV / rtp: and DTV (and file), when using this template "on movie file name match (with wildcards)":
Code:*262.262.68.86:5004*;*dtv:1*;*Jednotka HD*
TV archive link:
Code:https://www.joj.sk/silne-reci/archiv/2018-05-03-silne-reci
Code:https://nn.geo.joj.sk/storage/media-new/vod/2018/05/03/fa517438-b9c5-4c7e-be1f-b0f2210726e9-720p.mp4
Code:*joj.sk*
Where is the problem? Is it ffdshow issue, or PotPlayer issue? Is there any way to fix it, option I could try to change?Last edited by Dreamer; 7th May 2018 at 16:02.
PotPlayer: set hotkey to delete accessed file
By xtrips in forum Software PlayingReplies: 1Last Post: 15th May 2017, 18:44 -
How to set play speed in Potplayer?
By ampsc in forum Software PlayingReplies: 0Last Post: 5th Jan 2017, 16:59 -
How to set the charset for the second subtitle language in Potplayer?
By ilbrat in forum Software PlayingReplies: 0Last Post: 25th Dec 2015, 02:30 -
IPTV Set-top box vs HD TV Media Player
By siluet in forum DVB / IPTVReplies: 1Last Post: 5th Dec 2014, 19:27 -
How to set ffdshow 64bit as defaul x264 decoder?
By xicudiz in forum Software PlayingReplies: 10Last Post: 9th Oct 2013, 07:16
