If so, what editing software did you use?
The editing software I have produces problems at cut points with Rocket mp4 files, but not necessarily with non-Rocket mp4 files.
EDIT: Avidemux 2.7.1 32-bit version works where Smart Cutter 1.9.4 failed. Avidemux successfully edited mp4 produced by Hauppauge Rocket without leaving gray pixel blur at cut points, and it doesn't seem to re-encode if you select Copy. The resulting mp4 can be played on PS3.
What program are you using to edit?
Simple edits, maybe try AVIDemux or similar. Others here: https://www.videohelp.com/software/sections/video-editors-h264-avc
Problems at cut points are common for highly compressed video formats and with variable bitrate videos. -
Smart Cutter leaves gray blockiness at cut points: start, middle, end.
The video should be constant bitrate, if I remember correctly since the variable option is grayed out.
I'm interested in editing software someone has used and proved to be capable for Hauppauge Rocket mp4's, not random suggestions since I can't afford to buy all sorts of software just to see if they will work.
Any pointers for a Hauppauge Rocket newbie?
By GSP_87 in forum Capturing and VCRReplies: 4Last Post: 7th Sep 2017, 01:40 -
Hauppauge PVR2 - audio sync issue with Hauppauge Capture -- alternative?
By texas1 in forum Capturing and VCRReplies: 35Last Post: 2nd Apr 2017, 03:27 -
hauppauge hd pvr rocket to PC issues??
By Craigy J in forum Capturing and VCRReplies: 5Last Post: 24th Dec 2014, 04:48 -
"Hauppauge HD PVR Rocket" VS "AVerMedia Live Gamer Portable"
By SoundsGood in forum Capturing and VCRReplies: 10Last Post: 25th Mar 2014, 11:22 -
11 Programmes used - still can't join mp4 successfully?
By The.King in forum EditingReplies: 20Last Post: 13th Oct 2012, 03:32
