Hello.
I'm a bit stuck, and in need of some good advice.
I have PAL 1080i TV captures in .mp4 files - lots of very fast sports movement across a large grassed field with lots and lots of panning and zooming in and out and the ball tumbling in the air and bouncing around on the ground whilst beefy blokes crunch each other to get it and give it to their mates.
I need to convert and burn these to PAL DVDs for "timeshifted viewing", which means converting from 1080i-mpeg4-avc into 576i-mpeg2 (leaving as interlaced to maintain "motion fluidity" as I was once told years and years ago).
I rather fancy not installing using all-in-one type tools such as handbrake etc, even though they are marvellous.
I suppose Vapoursynth could be used to downsize via any of a few methods, eg
- qtgmc to deinterlace into double framerate progressive, then resize, then re-interlace
- yadifmod to deinterlace into double framerate progressive, then resize, then re-interlace
- DGDecodeNV which uses nvidia's cuda "purevideo" to deinterlace into double framerate progressive, then resize, then re-interlace
- DGDecodeNV which uses nvidia's cuda "purevideo" to deinterlace and resize in one go into double framerate progressive, then re-interlace
- a close-enough "pure" non-deinterlacing interlaced resizing method discussed briefly years ago
... but then, what tool to use to re-encode into PAL 576i-mpeg2 with bitrate circa 9400 Mbps, and how ??
Apparently HCenc is still considered by some to be the "best" mpeg2 encoder around, although I suppose nowadays that ffmpeg could have stabilized and be OK.
The thing is,
- I no longer have avisynth installed, only vapoursynth
- HCenc at http://hank315.nl/ says "Input can be a DGIndex/DGDecode d2v project or input using Avisynth" (a specific version of avisynth) ... so, no mp4 input file support available to me
- I have VideoReDo TVSuite V5 but it produced horrible results
- I have ffmpeg but am now unsure what commandline settings to use (and matrix, if one can be specified), it has been years since I did mpeg2 encoding
- I could pipe from vapoursynth/vspipe into something (I do now, into ffmpeg for other non-mpeg2 encoding)
- I do have the new Nero 2018 platinum (and am willing to try the Nero Recode, if you recommend it)
So, kind persons, may I have your good (and specific) advice on what tools and settings to use.
An example of the right settings on a commandline would be especially valued.
Results 1 to 20 of 20
Depends on your definition of "OK"
ffmpeg MPEG2 for DVD encoding is still poor. It's not as if there is a flurry of development for MPEG2 encoding. It produces about the same quality as it did 4-5 years ago. Which was pretty bad™. It's even worse for "film" DVD, no soft pulldown -
I do not understand your reluctance to install avisynth (for use within avstodvd) since you already use a variant of it.
And, as stated, the program only uses it when it needs to. Although you can edit the avs file within the program if you want to tweak it.
Offers several mpeg2 encoders as well.
Commercial over.
But, if you have a Blu-ray player, use the original recordings (unless they are too large) to make a avchd file with multiavchd and burn that to a dvd. Your Nero program might even be able to do that as well. -
All input valued.
Yes, Nero does. I am in the process of burning my first native blue-ray, via Nero, just because I can ... but currently can't afford to buy a blu-ray player given the minimal use it'd get
I did try Nero Recode but it came out looking quite grainy and the rich colours looked a bit washed out when viewed in mpc-hc which I'm guessing means some minor colour standard conversion also needs to happen (HD->SD) ? I'll need to google that in avisynth and vapoursynth, I guess.
Ah. Jolly, Bother and Dash it all.
OK, I'll put avstodvd on my list of things to try.
My goodness, what a really timely and interesting looking thread. Thank you ! I reckon my first port of call is to visit over there and poke around and maybe experiment a bit. -
Well, so much for the Nero 2018 Platinum "Nero Video" program to create a blu-ray from 1080i interlaced .mp4 files.
It right royally, and with great panache, screwed up the video (it tried to smart encode, which was nice of it).
Here's a jpg screenshot when a .m2ts is played with mpc-hc https://drive.google.com/open?id=0B5RV2aJ2vdhSMFJpdFNxbW1qNEk -
Well, that turned out to be relatively easy after all, thanks to some wonderful help from gonca over here, about using avisynth/GPU to feed HCEnc:
http://rationalqm.us/board/viewtopic.php?f=7&t=597
And info at these on how to not install avisynth, only needing to copy a few things into the right folders.
https://forum.doom9.org/showthread.php?t=172124
https://forum.doom9.org/showthread.php?p=1720075#post1720075
For posterity, in case it's handy for someone else, an example which worked in Win10 x64 :-
1. download and extract the latest HCEnc stuff from http://hank315.nl/ into a folder. In my case it was v0.28 into, say,
g:\hc
This will create these folders
g:\hc
g:\hc\DGDecode
g:\hc\matrix
g:\hc\misc
g:\hc\plugins
2. Download avisynth universal installer from here https://forum.doom9.org/showthread.php?t=172124
No need to run the batch file or use any admin privileges ...
2.1 Open the .7z file and extract the folder tree somewhere.
2.2 Copy these files/folder into the same folder as HCEnc - g:\hc
AVSPLUS_x86\plugins
AVSPLUS_x86\AviSynth.dll
AVSPLUS_x86\DevIL.dll
3. After donating to Donald Graft to use seriously GPU accelerated avisynth plugins (not an ad, this is what I needed to get huge FPS decode/encode speed, .mp4 input file support, other gpu plugins)
Download dgdecnv, refer here: http://rationalqm.us/dgdecnv/dgdecnv.html and here http://rationalqm.us/board/viewforum.php?f=8
And extract the 32bit .dll and .exe files etc into folder g:\hc\plugins
Remember to create the DG licence file in the same plugins folder as the .exe's are in - g:\hc\plugins
4. The rest can be automated by batch files and using different folders (and I will), however I did this by hand to see if it worked. It did.
4.1 Create a scratch folder eg D:\TEMP on a drive with lots and lots and lots of spare disk space
4.2 Create/edit the g:\hc\hc.ini file to look a bit like this, remembering my input is PAL 1080i mpeg4 and my ouput is to be PAL 576i mpeg2
The custom matrix I chose was "Fox New" just because someone recommended it for high bitrates. You could remove the line *PREVIEW if you wanted it to go a tad quicker. Depending on my prevailing video card's GPU I may try omitting *LOSSLESS to see if it's any faster.
4.3 Create/edit a new file g:\hc\HC-pal-dvd-interlaced.ini as a copy of the hc.ini above.Code:*DBPATH D:\TEMP *LLPATH D:\TEMP *BITRATE 9200 *MAXBITRATE 9400 *PROFILE best *AUTOGOP 15 *DC_PREC 10 *INTERLACED *TFF *CHROMADOWNSAMPLE 1 *CLOSEDGOPS *BIAS 50 *LASTIFRAME *PREVIEW *INTRAVLC 2 *CUSTOMMATRIX 8 8 9 9 10 10 11 11 8 9 9 10 10 11 11 12 9 9 10 10 11 11 12 12 9 10 10 11 11 12 13 13 10 10 11 11 12 13 13 14 10 11 11 12 13 13 14 15 11 11 12 13 13 14 15 15 11 12 12 13 14 15 15 16 8 8 9 9 10 10 11 11 8 9 9 10 10 11 11 12 9 9 10 10 11 11 12 12 9 10 10 11 11 12 13 13 10 10 11 11 12 13 13 14 10 11 11 12 13 13 14 15 11 11 12 13 13 14 15 15 11 12 12 13 14 15 15 16 *LUMGAIN 2 *LOSSLESS *PRIORITY normal *WAIT 30
4.4 Run DGIndexNV.exe over the input file g:\hc\test-HD-Q3.mp4 to save a .dgi file g:\hc\test-HD-Q3.dgi
4.5 Create a new .AVS file something like this g:\hc\test-HD-Q3.avs which is used as input to HCEnc and intends to use the GPU to do most of the hard work of: read the .mp4, deinterlace double framerate, resize HD to SD, sharpen a tad, re-interlace
4.6 create a new .bat file something like this g:\hc\test-HD-Q3.batCode:LoadPlugin("g:\hc\plugins\DGDecodeNV.dll") DGSource("g:\hc\test-HD-Q3.dgi", use_top_field=true, deinterlace=2, fieldop=0, resize_w=720, resize_h=576) Blur(0,0.25) DGSharpen(last, strength=0.3) SeparateFields().SelectEvery(4,0,3).Weave() #reinterlace - ASSUMED TFF HERE # BLUR(0,1) per http://forum.doom9.org/showthread.php?p=1488308#post1488308
4.7 double click on the .bat file and watch it runCode:@echo on G: cd "g:\HC" del "g:\HC\test-HD-Q3.mpv" type "g:\HC\HC-pal-dvd-interlaced.ini" type "g:\HC\test-HD-Q3.avs" HCenc_028.exe -i "g:\HC\test-HD-Q3.avs" -o "g:\HC\test-HD-Q3.mpv" -ini "g:\HC\HC-pal-dvd-interlaced.ini" -wait 10 pause exit
There you go.Last edited by hydra3333; 24th Sep 2017 at 01:14. Reason: spelling
This matrix is bit insane in case of DVD where strict max bitrate for video (going over 9100kbps is not recommended) limitation exist, MP@ML has internal limitation to 15000kbps - with such quantization matrix you may frequently go over MP@ML limit (btw pushing this kind of relatively flat matrix you may force encoder to use overall high quantization which affect seriously video quality - i would focus on lowering overall quantizer instead as it will be directly related to quality).
ffmpeg nowadays has also hq deinterlacer (NNEDI https://ffmpeg.org/ffmpeg-filters.html#nnedi ) available so Avisynth may be not needed at all and whole signal path can be closed within ffmpeg. -
OK, that's really good information, thank you. If you have a preferred matrix for that kind of material, what would it be ? I'll start looking at what's available in HCEnc, and likely start with its default mpeg matrix at a guess.
In regard to nnedi, ok yes that'd make it able to be done all within ffmpeg, and I was indeed eyeing off ffmpeg as a possibility albeit with vapoursynth for processing due to the variety of plugins available.
I wonder, posts around the place seem to suggest that HCEnc is still the "go to" mpeg2 encoder of choice for quality over ffmpeg, and DG's GPU avisynth plugin toolset is phenomenal at speeding things up. A trade-off ? -
But you can't really use it by itself, because it doesn't correct the field offset . It can be used as an interpolater with something like yadifmod or tdeint, but ffmpeg doesn't have it. But when you are downsizing 1920x1080 for DVD, it really doesn't matter that much as long as the field offset is corrected - you're not going to be able to tell the difference between yadif and something like qtgmc
For progressive "film" DVD you still need other tools, because no soft pulldown. Or suffer the inefficiency hit of encoding 25% more fields and interlaced encoding
For the settings suggested here
https://forum.doom9.org/showthread.php?p=1809116#post1809116
They need to be adjusted for "interlaced" encoding by adding "-flags +ilme+ildct -alternate_scan 1 -top 1" . But on some quick tests, they are actually not that bad. In some scenes maybe even slightly better than hcenc, but overall actually close. There are some issues, but I would say it's definitely usable now. -
Encode 23.976 fps progressive with ffmpeg then use dgpulldown to add pulldown flags.
I should probably mention that if your TV was purchased after 2011, it may have a built-in media player capable of playing HDTV files. I have a 2011 LG TV and a 2012 Samsung TV which are both capable of playing HDTV captures (from my PC TV tuner devices) via their USB ports. I use a USB stick, but a small 2.5" USB hard drive could work. A 3.5" USB hard drive with its own power supply would work too.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Can't disagree - with HD source yadif is sufficient and way faster.
Can't disagree - this is one of few main weaknesses of the ffmpeg presently (colour conversion is another very important part and reason why ffmpeg can't be considered as fully and complete solution for video signal processing). -
Ah, yes. This is the path I'll take then for time-shifted viewing, the original on a portable hard drive.
Well well, beaut ! Thank you. I'll give this a try, now that I've done the HCEnc thing and compare them (for longer term time-shifted viewing dvd seems best, disk drives seem to die every few years). -
I store HD recordings that I want to keep indefinitely on Blu-ray, DVD-R (if the files are small enough), or DVD+R DL, but without authoring or downscaling. Watching them again with a PC is acceptable to me. Authoring is reserved for recordings made by my DVD recorder from SD channels, as there is no reduction in resolution or significant quality loss.
Creating a DVD With Autostart W/O Looping Howto
By justasiam in forum Authoring (DVD)Replies: 3Last Post: 19th Sep 2016, 02:10 -
Mpeg2 video files duration 3hours burning on single dvd.
By nusratjaveid in forum Authoring (DVD)Replies: 3Last Post: 24th Jul 2016, 17:34 -
Cheap Video Processor Wanted to force 576i via HDMI on Satellite Receiver
By VideoFanatic in forum Capturing and VCRReplies: 1Last Post: 20th Feb 2016, 05:43 -
Converting VHS to DVD under Linux HOWTO
By danboid in forum LinuxReplies: 25Last Post: 9th May 2014, 07:10 -
Converting 8fps mpeg4 back to 25fps mpeg4
By Lynden in forum Video ConversionReplies: 7Last Post: 28th Oct 2012, 16:56
