    Jul 2016
    I have a folder of MKV's that I want to remux to into MKV into another folder but leaving out the subtitles so that only the main video and audio tracks after left with chapters also.
    i have tried to find some scripts online and change the relevant paths to what I need but have had no luck of it working yet.
    I have also tried MKVBatch which just crashes when it starts to remux the files.
    Is there a easy to use script that can do this where it takes all the MKV's in a folder and does what I mentioned above?
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    Try JMkvpropedit it works. And it is really fast. It works with all files in folder. I didnt test it with subtitles, but it should work. There is panel. But I am not sure if it removes anything physically. The size seems to be same. But when you open it in mkvtoolnix, it didnt show striped tags etc.
    Bernix
    Edit Quick check but I cant figure how to remove subtitles... Everything else is straight forward. Sorry
    Jul 2016
    I have tried that and it doesn't remove subtitles unfortunately.
