So I have a MKV movie file and when i play it the audio has a commentary with so then i googled and see what i can do to delete and I came across the MKVToolNix after doing the using the "multiplex" and yes i unchecked the files that i don't want to be copied and yes i changed the "compression" to " no extra compression" and even after doing all that when i played the the new mkv file there is no audio ... can anyone help me with this problem ... thanks in advance
Closed Thread
Post A MediaInfo report of the MKV file involved
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 21mn
Bit rate mode : Variable
Maximum bit rate : 34.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : Avengers.Age.of.Ultron.2015.1080p.BluRay.REMUX.AVC .DTS-HD.MA.7.1-RARBG
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 21mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 21mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.49 GiB (5%)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : A_AC3
Duration : 2h 21mn
Bit rate : 320 Kbps
Channel(s) : 2 channels
Stream size : 323 MiB (1%)
Language : English
Default : No
Forced : No
Audio #4
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 21mn
Bit depth : 24 bits
Language : Spanish
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Duration : 2h 21mn
Bit rate : 640 Kbps
Stream size : 647 MiB (2%)
Language : Hindi
Default : No
Forced : No
Audio #6
Format : AC-3
Codec ID : A_AC3
Duration : 2h 21mn
Bit rate : 192 Kbps
Stream size : 194 MiB (1%)
Language : English
Default : No
Forced : No
MKVMerge GUI not in my MKVToolnix
By gumbygum in forum EditingReplies: 4Last Post: 23rd Mar 2017, 01:44 -
MKVToolNix GUI not importing subtitles from MP4...
By syrist in forum Video ConversionReplies: 5Last Post: 23rd Jan 2017, 10:34 -
AR (aspect ratio) 2.21:1 in tsMuxer 2.6.12 and in MKVToolNix GUI 9.2.0 ??
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 4Last Post: 16th Dec 2016, 06:36 -
MKVToolNix GUI muxing - problem with chapter
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jun 2016, 23:18 -
MKVToolNix GUI v8.9.0 issue with timecodes
By Han Solo1 in forum Newbie / General discussionsReplies: 6Last Post: 13th Mar 2016, 19:55
