Hi all,
I take a lot of videos with my Galaxy Samsung S7 @ 60fps. I use 60fps because I do a lot of fast panning and quick activities which require the extra frames resulting in a more smooth video. The videos I take are usually around 25000kbps.
I use Sony Vegas to edit them into a single video and render at 60fps and take the quality down to 15000kbps.
The resulting videos have random choppy/jerky moments in them. They don't appear to be random. I re-play the video and the choppiness appears at the same point in the video. Something strange happened during conversion and I'm not sure what it is! I did not change the frame rate and I do not 'allow the source to change the framerate'.
Has this happened to anybody else? I can provide exact conversion details if needed
thanks in advance
Variable frame rate ?
You set Vegas project with 60fps, export 60 fps but new frames needs to be created anyway here or there.
Without an example difficult to be exact. Try to set disable re-sample for the clip if it is going to look better. Vegas would just copied missing frames. -
Hi,
The exact input fps is the exact output fps. So no frame-play is taking place.
Disable re-sample does not come into play at all when fps is the same. -
if you uploaded before and after sample someone might be able to help. not enough info without. it doesn't happen unless you are doing something wrong.
Open your encoded video in an editor and step through frame by frame. Are there any duplicate frames? Missing frames?
Yes, unless video has variable frame rate, can you confirm it is not the case?
When you check clip properties and media TAB, format attributes, do you see exact 60.000fps or some other number that is pretty close to it? That would mean variable frame rate. Note, 59.940 would be ok, that is not a variable frame rate and project should be set with that frame rate as well, but I doubt that Samsung records that frame rate, I could be wrong though.
Or check mediainfo listing.Last edited by _Al_; 21st Sep 2017 at 21:08.
Sony Vegas Pro 12 Video Proxies and 60fps rendering
By jcarst85 in forum Newbie / General discussionsReplies: 6Last Post: 11th Apr 2015, 01:59 -
Sony Vegas x264wfv output changes red color
By LeoKac in forum Video ConversionReplies: 2Last Post: 25th Mar 2015, 09:17 -
60fps playback perfect, 30fps choppy stutter (YouTube)
By mr2ggaming in forum EditingReplies: 17Last Post: 28th Nov 2014, 21:03 -
Choppy/jerky output video after rendering, what's the issue??
By xiaok23 in forum EditingReplies: 3Last Post: 12th Oct 2013, 14:01 -
Video in Sony Vegas Pro 12 Horribly Choppy/Distorted in Preview AND Render!
By Baasha in forum EditingReplies: 8Last Post: 27th Sep 2013, 14:27
