  1. As of at least a few weeks ago, I was able to use see the .m3u8 links while playing a video in a browser. They were then easily saved with livestreamer.
    Now when playing a video the video shows up as directly saveable .ts files, a few seconds long.
    eg. https://www.nbc.com/days-of-our-lives/video/friday-september-15-2017/3581450
    https://nbchls-prod.nbcuni.com/tve-adstitch/647/17/09/07/3581450/E1D97AF297DA66339C8F6...DC19A5FBC-1.ts
    https://nbchls-prod.nbcuni.com/tve-adstitch/647/17/09/07/3581450/E1D97AF297DA66339C8F6...DC19A5FBC-2.ts
    https://nbchls-prod.nbcuni.com/tve-adstitch/647/17/09/07/3581450/E1D97AF297DA66339C8F6...DC19A5FBC-3.ts
    I have no idea where to go from here....
  2. Yes, u are right, I also noticed the video stream of NBC has changed, and the methods of using Livestream is invalid.
    Until now I did not find a proper method, can someone kindly solve this problem..... welcom
  3. Originally Posted by sysanin View Post
    thanks for suggestions
    Tubedigger wouldn't even load it
    HLS Stream Detector did find links, but it seems to be only the ads
    Jul 2017
    North Pole
    you can download it atleast with the latest youtube-dl.exe ...
    works with tvdownloader ...
    and btw, change https to http in the url,or its not working
  5. Originally Posted by Kamala View Post
    ugh, are you friggin kidding me?!
    the "s" was the reason it wouldn't work....because I know I tried both before, but tvdownloader just found it fine
    greatly appreciate the help!
    Jul 2017
    pasadena , md
    I'm Having the issue of downloaders only downloading the ads.
    Usually I can download videos from nbc fine with the allavsoft video downloader app. i just throw the link in the app in it detects and DLs the video fine.
    But recently NBC has locked some its content.You need a cable sub or you create a account on nbc and watch 3 locked videos without needing a cable sub. so i need to actually be on the web browser to download the video.
    But all the add-ons and extensions video dls only download the ads. i've tried Internet download manager,video download helper, there is a allavsoft extension but that doesn't seen to show up on nbc's site
    Anyone have any ideas?
    https://www.nbc.com/dateline/video/in-broad-daylight/3608907
  7. Member Emeritus
    May 2014
    Originally Posted by Chronos2086 View Post
    ... recently NBC has locked some its content.You need a cable sub or you create a account on nbc and watch 3 locked videos without needing a cable sub. so i need to actually be on the web browser to download the video.
    youtube-dl supports provider authentication. If you are using the "3 free" login instead of provider authentication, then view the network traffic using browser developement tools and filter for a url that looks something like this;
    http://nbcmpx-a.akamaihd.net/video/406/163/171026_3608907_In_Broad_Daylight_anvver_7_4000.mp4?hdnea=st=1509829829~exp=1509842459~acl=/video/406/163/171026_3608907_In_Broad_Daylight_anvver_7_*~id=d19125f0-d596-4d6e-bba6-029534c3f85e~hmac=13e980fb314d01fdcb0377d00be8206b4c3ab16e
    It should download super easy. There is also hls which can be downloaded with livestreamer or streamlink.
