Firstly thanks to the creater of this thread and the creater of thi prog too.
I have a 45GB iso in 3d and wourd like to convert it to .mkv and in 3d too. This is what came as a result of the first phase:
Job finished Sat Mar 31 20:34:40 CEST 2018
Whole job took 31 minutes and 51 seconds.
Done with warnings!
* Warning: Subtitle track "00000.track_4609.Ger.2D.sup" is not associated with any 3D-plane.
Using 3D-Plane #1 (file 3D-Plane-01.ofs) instead of plane #255.
The subtitle depths may be wrong.
Launch "__ENCODE_3D_LAUNCHER.cmd" to encode the 3D video (and optionally mux to MKV).
When i do the launching nothing happens:the cmd window loads the file and that is it.
Eager waiting for your tips.
Results 31 to 37 of 37
What do you mean with "that is it". The CMD windows closes immediately ?
Anyway, try to edit the __ENCODE_3D.cmd (not the launcher) and add a "pause" command at the end of the file. Then launch it. If it displays an error message, copy it and post it here.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV -
Thanks and sorry for late reply. The process was at last successful after 5 trys.
i had an issue but resolved (avisynth not installed)
Hi again r0lZ!
I have a new PC, new Windows 10 (1903) and new problems
Everytime I try to encode a BD3D iso it stops suddenly after the dialogs retireving all the files. A CMD window appears with "0000.264 could not be recognized" or something along these lines. Forgive me for not being explicit, but I hope you get the idea. Even if I execute the __ENCODE_3D_LAUNCHER.cmd manually inside the folder, it gives me the same error. Also, it says something about avisynth, but I have the latest version installed as well. Any clues of what's happening? It worked flawlessly on the previous PC build - and besides the obvious function I want to see it running with the new CPU.
Cheers, -
Have you the very last version (v1.14) ? There is a bug in v1.12 and v1.13 that I have just fixed and that can explain the problem.
Also, make sure that you have installed Avisynth. Currently, the recommended version is AviSynth+ 64-bit. (See the Help menu.)
Finally, verify that the files from the BD3D2MK3D archive have been extracted with their path. You must have a folder "toolset" in the BD3D2MK3D installation folder.
If nothing above has fixed your issue, please retry and copy here the EXACT error messages, and when exactly they occur.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
Hi. I try to create a file from 3D BluRay sbs.mkv half
By JhonDown in forum Video ConversionReplies: 16Last Post: 21st Mar 2016, 22:26 -
Extract/convert/ripp/copy u name it 3D blueray iso to mkv sbs
By dannydevito in forum Blu-ray RippingReplies: 0Last Post: 19th Jan 2016, 03:47 -
3D Bluray to SBS MKV on OS X
By ddregs in forum Blu-ray RippingReplies: 1Last Post: 7th Jan 2016, 15:10 -
MKV cropping 3d sbs files
By woody565 in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2013, 00:48 -
Swap Left/Right images in a 3D SBS mkv
By Ziad87 in forum Video ConversionReplies: 5Last Post: 7th Mar 2013, 12:37
