Hi,
I'm currently in the process of converting some m2ts files from blurays to 720p with handbrake. I'd like to know if it is safe to use constant (not variable) "same as source" frame rate when converting? or is there a risk that the audio will unsync?
thank you!
Handbrake is very good at maintaining audio sync regardless of the output you use, but be careful with the frame rate you choose. If it doesn't match the actual video frame rate Handbrake will repeat or drop frames as required to output the requested frame rate.
For NTSC hybrid DVDs (combinations of "23.976 fps film" and "29.970fps video") choosing a constant frame rate "same as source" will possibly repeat frames during the film sections for a constant 29.970fps, which isn't ideal. That's the whole point of using a variable frame rate if need be.
For constant frame rate sources, which Bluray sources often are, you should get a constant frame rate even if you choose variable for the output.
If in doubt, check the log file after encoding. I don't use Handbrake much myself but the older version I have installed includes this sort of thing in the log file:
The last line isn't included unless you specify a constant or peak frame rate. If there's no frames being dropped or duplicated, ideally that'd be what you want.[17:26:11] + Framerate Shaper (1:27000000:1126125)
[17:26:11] + frame rate: 23.976 fps -> constant 23.976 fps
17:26:17] sync: got 1199 frames, 1200 expected
[17:26:17] render: 1199 frames output, 0 dropped and 0 duped for CFR/PFR -
No it's the other way around. A VFR output will never cause Handbrake to duplicate/drop frames. If the source is CFR the output should be CFR even if you select VFR. The last line in the log file I quoted tells you what Handbrake needed to do to achieve a CFR (or peak frame rate) output if you selected CFR (or peak frame rate) for the output.
I think the choice of VFR or CFR really only matters if you're using the decomb filter as it's inherently VFR. For hybrid NTSC sources (combinations of film and video) it outputs a combination of 23.976fps and 29.970fps, so when you select CFR as the output, Handbrake has to add/drop frames as required be to give you the desired constant frame rate. If you're not using the decomb filter (and for totally progressive, CFR film on Bluray you wouldn't need to) then VFR/CFR "same as source" should give you the same result. Hopefully that makes sense. If in doubt though, check the log file if you select a CFR output.Last edited by hello_hello; 18th Sep 2017 at 23:04.
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 16:42 -
Do I need to resize 1080p PGS subs to 720p when making 720p AVCHD ???
By FulciLives in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Aug 2015, 12:26 -
Change video from 1080p to 720p
By insidesafstand in forum Newbie / General discussionsReplies: 17Last Post: 1st Oct 2013, 08:45 -
Alternative to SUPER for converting files to DVD w/o losing audio sync?
By ibzomie in forum Video ConversionReplies: 3Last Post: 17th Feb 2013, 03:22 -
Resize re-encode 1080p to 720p > Re-encode 720p to 720p?
By Anonymous54873 in forum Video ConversionReplies: 17Last Post: 10th Jan 2013, 23:19
