I have about 90 hours of video on mini dv tapes that I need to get on my computer. I no longer have the firewire equipment that I once used. Is there some other hardware convert that I can use?
Richard
Depends on the outputs from the camera. USB converters generally use composite input, not great quality.
If the camera has S-Video, much better. Or HDMI, though the converters can be expensive.
Alternatively, find a Firewire card for the PC. Ebay is one inexpensive source.
What camera do you have?
But others may have better ideas.
And welcome to our forums.
MiniDV data transfer via Firewire vs. some sort of analog capture device?
No brainer...get a firewire card. -
That computer could be rally old one and you do not need to be connected to internet or your own LAN (safety), I'd just ask around if needing one. if that computer was bought after 2000 approximately it should be alright as long as it has a room for that card. Just clean it with ccleaner , uninstall whatever programs you can, do not allow many known applications to run at startup that does not have to be running. Get some firewire card, use Scenalyzer Live to capture miniDV tapes. If not having anything to play those miniDV tapes with firewire out, that I guess is bigger problem than not having a computer.
Why did Apple drop the mini 3 but keep the mini 2?
By jyeh74 in forum ComputerReplies: 0Last Post: 10th Sep 2015, 12:15 -
Conversion of DV-AVI files captured on Mini DV camera
By NE1WeKnow in forum EditingReplies: 10Last Post: 13th Jul 2015, 05:14 -
mini dv and PAL
By granturissimus in forum Capturing and VCRReplies: 6Last Post: 5th Aug 2013, 07:26 -
Using Sp/LP mini DV in a Sony Mini DV Player
By Gsmurfet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st May 2013, 21:38 -
mini dv to pc
By JonFC in forum Newbie / General discussionsReplies: 7Last Post: 28th Sep 2012, 15:17
