  1. Hi,
    I am looking to do 2 things.....
    1. Is it possible in avisyth to custom crop a video clip on a frame by frame basis? (in parts of the video the black bars are bigger then in others so a single crop fits all wont do)
    2 I know it is possible in avisyth to grab a frame and turn it on to an image. But is it possible to grab sections of the image (like tiles if you will) and move them around?
    if avisyth is not the thing to use, what can I use?
    thank you for your time.
  2. Originally Posted by ZenMystic View Post
    Yes, as long as they're then resized to all the same resolution.
    2. Yes, but probably not a whole lot of fun to do. You'd crop down to the section you want and then overlay it where you want.
  3. For example:
    function circular(clip bg, clip ovr, clip alpha, int ang)
    	x = int(cos(ang*2*3.14159/360.0) * bg.height/2)
    	y = int(sin(ang*2*3.14159/360.0) * bg.height/2)
    	ovr = ovr.Rotate(ang)
    	alpha = alpha.Rotate(ang).ColorYUV(cont_y=34)
    	Overlay(bg, ovr, bg.width/2-ovr.width/2+x, bg.height/2-ovr.height/2+y, mask=alpha)
    function linear(clip bg, clip ovr, clip alpha, int xpos, int ypos)
    	xpos = (xpos/2)*2
    	ypos = (ypos/2)*2
    	Overlay(bg, ovr, mask=alpha, x=xpos, y=ypos)
    ColorBars(width=1280, height=720).ConvertToYV12().Trim(0,99)
    block = Crop(150,450,128,128)
    alpha = Crop(250,560,128,128).AddBorders(16,16,16,16).BilinearResize(16,16).BicubicResize(128,128).ColorYUV(gain_y=150, off_y=-90)
    Animate(0,100, "circular",  last,block,alpha,0,  last,block,alpha,360)
    Animate(0,100, "linear",  last,block,alpha,-100,-100,  last,block,alpha,width+100,height+100)
  4. I am wording if anyone can help me... As I have no idea how to clip black bars from a video clip. The bars are of different thinkness... Same frames have more black bar in them than others. In fact some frames have no blacks bars at all.
    How do you get avisyth to crop all the black bars?
    I have tried using the plagins AutoCrop() and RoboCrop() with no luck.
    I'd like to write my own script but no idea how.
    Can anyone help?
  5. You have to break the video into segments, crop them individually, then join the back together. But remember, all parts have to have the same size on output. Say you have a 720x480 frame:
    WhateverSource("filename.ext")
    part1 = Trim(0, 999).Crop(0, 60, -0, -60) # leaves 720x360
    part2 = Trim(1000, 1999).Crop(0,120,-0,-0) # also leaves 720x360
    part3 = Trim(2000, 0).Crop(8,40,-8,-40).Spline36Resize(part1.width, part1.height) # cropping and resize to match others
    part1++part2++part3
  6. Member Cornucopia's Avatar
    If they are different thicknesses like you say, doing such as you intend is going to give you a quite disturbingly jumpy picture. May need to keep your changes limited to ~ every 3 seconds minimum.
