    Mar 2011
    Paris, France
    Hello,
    I'd like to replace the bad audio in an MP4 file with a better copy available as a separate audio file.
    Is there a good, easy to use (Windows) application to sync audio and video?
    Thank you.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How long is the video?
    Something like a single music video, not so bad....an entire movie? Not something I would want to try.
    Are the run times/duration of the two files even remotely similar to each other?
    Mar 2011
    Paris, France
    It's just a 10mn file of a conference.
    There's about 30s extra at the beginning of the video file that I'll trim with eg. ffmpeg.
    Ideally, I'm looking for a GUI-based solution that makes it easy to shift the audio a bit until it's in sync, and save the combo as a new file.
  4. Try VirtualDub Filtermod. Enable: View -> Audio Display.
    Mar 2011
    Paris, France
    Thanks.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use an old version of AviDemux to replace audio. No re-encoding of video if done properly.
    Mar 2011
    Paris, France
    I'll give it a shot.
