Hi!
I'm using for capturing PEXHDCAP from StarTech.
It allows me to capture VGA, DVI, HDMI, Component with audio up to FullHD.
I'm using for capture manufacturer software StreamCatcher.
This is very simple tool, but for basic capturing it is enough.
It allows only change color scheme, but not to store them to any profile. It has only few filters.
I'm using also basic AMCap where can have different color scheme and it applies on default parameters - so I can use 2 color profiles... StreamCatcher and AMCap.
Exist any capture software which allows create own color profiles and store them, then use by selection?
Thank you for help.
Miro
Results 1 to 1 of 1
A software to hardcode subs with font options (changing color)?
By exwoll in forum SubtitleReplies: 11Last Post: 8th Feb 2016, 12:18 -
Which software is best for color adjusting of capturing video?
By miro@hotmail in forum Capturing and VCRReplies: 2Last Post: 1st Nov 2014, 23:52 -
Capturing and color corrections results - which software to use ?
By miro@hotmail in forum Capturing and VCRReplies: 3Last Post: 18th Aug 2014, 14:22 -
need help creating boot disc of any software
By pappubeta in forum ComputerReplies: 3Last Post: 23rd Nov 2013, 15:37 -
Can you undo in software sephia color in video
By mammo1789 in forum RestorationReplies: 14Last Post: 6th Jun 2013, 08:44
