Hi all,
I've being using MPC-HC for years on many setups, I always install the portable x64 version, run it with default settings and everything is fine.
In my latest laptop (MSI GL62 with Intel HD 630 and NVIDIA 1050Ti), the video is choppy.
I have the latest driver for the Intel HD 630 (from last month) and for NVIDIA (same, from last month).
Device manager is all clear from issues and everything is recognized.
The coppy playback happen on all type of files, from 720P to 1080P and increase as I increase the screen of the MPC-HC window. Same happen with VLC. If it helps, when I try to play with the volume keys (up and down arrow), the playback almost stop!).
Check out the image below: https://imgur.com/a/Ljbu4
Would appreciate any help.
Take a look at the guide here: http://www.avsforum.com/forum/26-home-theater-computers/1357375-advanced-mpc-hc-setup-guide.html
Google is your Friend -
Your renderer device is HD 630. Switch it to Nvidia 1050 TI which is about 3 - 4 times faster.
Bernix
Seamless playlist playback in MPC
By dmjerbear in forum Software PlayingReplies: 10Last Post: 19th Aug 2021, 19:21 -
MPC-HC Juddery Playback
By VideoFanatic in forum Software PlayingReplies: 7Last Post: 28th Dec 2018, 08:42 -
Choppy video in MPC BE
By maxiu in forum Software PlayingReplies: 5Last Post: 7th Dec 2014, 10:22 -
MPC-HC playback issues .. [resolved]
By vhelp in forum Software PlayingReplies: 12Last Post: 10th Aug 2013, 15:58 -
MPC-HC DVD Playback Issue
By Roscoe1891 in forum Software PlayingReplies: 2Last Post: 5th Jan 2013, 21:16
