How can I get the metadata from an HDR10 video (such as MaxCLL and MaxFALL)?
I really appreciate your help.
Results 1 to 9 of 9
I tried it but the information about MaxCLL and MaxFALL are not displayed.
General
Unique ID : 179768350720378371925034052307682204296 (0x873E1FFE11E218779845D5E9E7621A88)
Complete name : F:\10bitimages\HDR10Video\The_World_in_HDR_in_4K_H DR10.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 308 MiB
Duration : 2 min 34 s
Overall bit rate : 16.7 Mb/s
Movie name : The World in HDR in 4K - Demo-UHD3D.com
Encoded date : UTC 2017-04-24 13:38:07
Writing application : mkvmerge v11.0.0 ('Alive') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 16.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 FPS
Bits/(Pixel*Frame) : 0.033
Stream size : 306 MiB (99%)
Default : Yes
Forced : No
Audio
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Bit rate mode : Variable
Bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 48.199 FPS (915 SPF)
Compression mode : Lossy
Stream size : 2.02 MiB (1%)
Writing application : Google
Language : English
Default : Yes
Forced : No -
Open a request for MediaInfo (you can cut e.g. first 5 seconds using mkvtoolnix):
https://sourceforge.net/p/mediainfo/bugs/ -
You're a beginner in this field yet you are asking details about HDR metadata?! Something doesn't jibe.
Scott -
Yes I am. I need to get the MaxFALL and MaxCLL of an HDR10 sequence.
I downloaded many HDR sequences from http://4kmedia.org/ and tried to get these information using mediainfo as sneaker's comment above but I couldn't.
Now I am wondering that my sequences are HDR10 or not because as far as I know, the HDR10 metadata must contain MaxFALL and MaxCLL.
Do you have any suggestion?
HDV Metadata
By SameSelf in forum Video ConversionReplies: 1Last Post: 7th May 2015, 21:12 -
Change Metadata
By Rulez in forum Video ConversionReplies: 6Last Post: 19th Nov 2014, 08:22 -
Video Metadata
By Bwizzy in forum Video ConversionReplies: 5Last Post: 21st Apr 2013, 02:06 -
Edit metadata?
By w1n78 in forum Video ConversionReplies: 4Last Post: 16th Jan 2013, 12:08 -
jpg metadata
By hcs in forum Off topicReplies: 5Last Post: 8th Dec 2012, 15:18
