Good day all
I'm busy putting together some feedback on a commercially pressed DVD. The disc lags on both a set-top player, and when played back on my PC. The video looks like it's somewhere between 15 and 20 FPS, instead of the intended 25 for PAL.
I've checked the VOB files with MediaInfo, and they come back as 25FPS, with an average bitrate of 6mbps.
The disc behaves the same on all players I use. And all other discs work normally, and smoothly.
What I'm now trying to do, is find a way to prove that is an issue, other than to subjectivly view the disc itself.
My thoughts are, that the actual disc would pass a cursory check, but that there was likely an issue with the source material, or in the telecine process.
Any suggestions would be greatly appreciated!
Step through the video frame by frame in an editor. Does the picture change with each frame? If not, you need to figure out what went wrong in your editing and authoring.
Thank you!
DVDinfo says the disc doesn't have CSS so will try one of the VOB files
Thanks for the suggestion! -
Some quick feedback. When stepping forward frame by frame, every third frame seems repeated
Seems they used a 24 @ 25 Repeat pulldown method
Would I be correct in assuming this would have been caused at a point during the conversion from 24 FPS to PAL 25?
Either way, it becomes far more obvious when stepping through motion (especially large objects)Last edited by andrewgerm; 14th Sep 2017 at 10:56. Reason: Additional info added
Like ABCCDEFFGHII ? That implies a 25*3/4 = 18.75 fps frame rate. Or do you mean ABBCDDEFF ? That indicates 25*2/3 = 16.7 fps.
2:2:2:2:2:2:2:2:2:2:2:3 pulldown would not give you repeats every 3 frames. 24 fps film is usually just sped up to 25 fps (resulting in a ~4% shorter running time).
What was your source? 8mm film? That's typically 16 to 18 fps.
PotPlayer - 1080p lag
By jackuars in forum Software PlayingReplies: 10Last Post: 10th Apr 2016, 16:39 -
Game lag pixels.
By Jappyanime in forum ComputerReplies: 13Last Post: 20th Nov 2015, 14:04 -
Audio lag during conversion
By luachhabibi in forum Video ConversionReplies: 8Last Post: 16th Aug 2015, 13:46 -
POTPLAYER - lag when seeking
By skribby in forum Software PlayingReplies: 9Last Post: 9th Aug 2015, 18:09 -
Need no lag capture card to play xbox one on my pc with no lag
By joeyiswhammo in forum Capturing and VCRReplies: 6Last Post: 31st Aug 2014, 11:41
