Hi,
Can anyone recommend a fast (and free) DirectShow video renderer filter, which seems under devices (I test with AMcap) like a webcam? I have an industrial camera with BYBG color space, it seems under devices but the whole screen is black. It works fine under GraphEdit with the default Video Renderer, but I would like to use as a virtual webcam with high frame rate and original resolution. Maybe another solution to use the original capture source converted to grayscale the output pin, without virtual video renderer ...but I don't know how.
Thank you!
Try ffmpeg dshow
https://trac.ffmpeg.org/wiki/DirectShow
If it's listed under devices, then you can use ffplay to preview or ffmpeg to maniulate, record etc.. -
I don't fully understand what you're trying to say. Did you mean hardware device ?
Because you can broadcast/stream the camera to ffmpeg output over ip (like a webcam)
https://trac.ffmpeg.org/wiki/StreamingGuide
Or you should be able to build your own player /front end from ffmpeg
Or did you want some pre-made GUI ? If so, did you try searching for webcam software ?
Camera or Video Camera for film?
By Orange Fox in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Sep 2017, 19:48 -
"Industrial" JVC SR-S388 with 1261 hours. Would this scare you?
By pcip in forum RestorationReplies: 9Last Post: 30th Mar 2016, 03:28 -
Laboratory/Industrial Grade VHS Players?
By Hessian in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2013, 17:53 -
Video from Camera displays incorrectly on comptuer, but fine on camera & TV
By g6qwerty in forum Video ConversionReplies: 2Last Post: 31st Jan 2013, 23:02 -
Looking for a new webcam
By canadateck in forum Video Streaming DownloadingReplies: 2Last Post: 29th Dec 2012, 18:15
