I tried playing the sample of Elysium off 4K samples with MPC-BE & the video stutters & cpu usage is 99-100% according to task man.
My cpu is an older i7 870 stock at 2.9ghz. I tried this vid on another semi decent laptop & the stuttering & usage is crazy high to.
Why is the usage so high? Other 4K videos barley use 25%.
If this is so high, How would modern quad cores perform? Would they generate alot of heat?
Results 1 to 11 of 11
AnonymousGuest
To playback HEVC you need a top notch CPU, That is if you software decode. A high end i7 might not even be enough..
If you have a graphics card that can hardware decode HEVC you need al lot less cpu like i5 or even a high end i3 will do. -
A NVIDIA GT 1030 (2GB VRAM) could provide 10-bit HEVC hardware acceleration for playing video files at a reasonable price. However, you would need a NVIDIA GTX 1050 Ti to meet the memory requirement (at least 3GB VRAM) if you want to subscribe to Netflix 4K.
[Edit]The GPUs in Kaby Lake and upcoming Coffee Lake i3, i5, and i7 series CPUs can also provide 10-bit HEVC hardware acceleration. However not many motherboards provide HDMI 2.0 (required for HDR 10 + 2160p60fps) and HDCP 2.2 (required for commercial streaming services). The above NVIDIA GPUs also provide HDMI 2.0 and HDCP 2.2.
UHD Blu-ray playback requires Kaby Lake or Coffee Lake i5 or i7 series CPUs plus a motherboard with HDMI 2.0 and HDCP 2.2 and SGX support. Graphics cards can't be used for UHD Blu-ray playback because of the requirement for SGX.Last edited by usually_quiet; 13th Sep 2017 at 13:56.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Well I have to read up more when I get a chance, but it seems like the jump from h.264 to h.265 is only a small increase in PQ but 10X more demanding just so they can fit those 4K movies on a BD disc. And force old desktops to be completley upgraded.
I watched two Elysium trailers in 4K, one was good old h.264 & ran perfect smooth & only looked a tad softer to my eyes image quality vs. the HEVC version.
Also some 4K trailers online in H.264 like honey bees look absolutely amazing, so the codec looks to be only as good as the camera being used.
Does anyone think if I overclock to around 4GHz with good cooler would play these HEVC 4K alright? -
AnonymousGuest
I don't think that overclocking would be of much help, but you could try.
Though air cooling might not be enough so water cooling is almost a must.
I would stick to H264 for now or buy one of the above suggested NVIDIA GPU'S
Personally i think that the biggest advantage of H265 is for streaming services like Netflix, Slightly better picture quality but at roughly half the file size -
I have the GTX970 on my system (it's not officially supported on vista, but plays my older games no probs). When playing back the 4K HEVC video according to gpuz there is a moderate load on GPU averaging around 15-25% i think, while CPU is 95% usage average. I have experimented with settings in MP-HC GPU acceleration & all settings the video stutters.
Does this mean the CPU just needs some more speed or maybe it means not much? Just curious. -
AnonymousGuest
It simply means that your CPU is doing all the decoding work, hence the high usage.
With proper hardware acceleration this would be reversed, the GPU will do all the work instead of the CPU -
Something I neglected to mention in my other post: Windows 10 is listed as a requirement for both 4K Netflix and UHD Blu-ray playback. Microsoft only supports Windows 10 with Kaby Lake and later Intel CPUs and the required NVIDIA driver (GeForce 384 Series Driver) which allows 10 series GPUs with 3GB+ of VRAM to work for 4K Netflix with any CPU, is for Windows 10. http://www.nvidia.com/download/driverResults.aspx/120486/en-us
Other paid 4K streaming services may have different requirements, but it's possible that Vista won't be supported for 4K or that streaming their 4K material isn't supported for PCs at all. Potential subscribers will have to look at the hardware and software requirements before signing up.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
In that case, you should wait.
I have been experimenting with 4K on my present Haswell i5 computer, although the iGPU and HDMI 1.4 are limited to 30fps with 2160p video. The iGPU provides H.264 hardware acceleration, but only partial 8-bit HEVC hardware acceleration. H.264 plays smoothly. HEVC does not.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I've had the same stuttering problem on every video file I've tried. I changed every setting I could think of and still the same. I finally decided to uninstall nividia and reinstall. Still the same. I uninstalled and reinstalled against but this time I didn't install the game ready drivers. Now everything plays perfect and the colors aren't over saturated. Even an HVEC 4k HDR movie that's 71gb plays perfect. There must be issues with the game drivers. Also, after I installed without the game drivers I now have 10bit option in display resolution. Before I had only 8 and 12bit.
Last edited by allen69; 15th Jan 2018 at 02:42. Reason: found more useful setting.
ffmpeg CPU usage
By diprotic in forum Video ConversionReplies: 13Last Post: 19th Apr 2015, 15:40 -
Can't get 100% cpu usage when using Megui
By Tylerr in forum Video ConversionReplies: 5Last Post: 30th Jul 2014, 22:19 -
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 20:13 -
How to keep low cpu usage in JW player 6
By vijay123 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Aug 2013, 14:54 -
100% CPU Usage - Is this bad for my PC in the long term?
By Ronaldinho in forum ComputerReplies: 26Last Post: 9th Jun 2013, 12:57
