I just bought a "new" vcr to start converting videos myself, and I can't get it to power on. It's a JVC HR-S7600u.
I first plugged it in and put in a video tape to test it - the video played for maybe 1-2minutes, and then I decided to check on how it adjusted tracking later in the video tape. I FF to about 15 minutes into the tape and then hit play. It played for a short time, and I started playing with the "date" "channel" buttons and "stop/start" buttons on the remote because the channel button is how to adjust tracking, but then the tracking wasn't changing, so I tried the other buttons.
VERY soon after that the vcr powered down - there was still a display, "AUTO" was blinking, but the vcr wouldn't power on long enough to play the tape. It wouldn't even turn on long enough to eject the tape. I tried pushing just about every button after that, and when I hit the timer button the tape ejected (since the tab was popped to protect the tape - it's not a tape that's able to record and when in Timer mode it ejects).
Since then I've looked up the manual and I thought perhaps the Plug & Play was the issue - they said that I had to have the cable hooked up to it so the device could scan and find the local PBS station that would send the time signal. I hooked up the cable - unplugged the vcr for more than a half an hour - plugged it back in so it could find the cable and get set up. I left for work, came back, and the time still hasn't set, the power still won't come on.
Is there something I'm missing or is it just broken?
Thanks!
Susen
	Sounds like a faulty VCR.
 The time issue doesn't affect the basic function of the player (at least not that I recall as I had this deck years ago). The unit should always power on and function. The "AUTO" will continue to flash until the unit pulls the time info (which I don't know is still relevant).
 From another forum:
 Take your factory remote & hold the power button down on it for 6 to 10 seconds (aim it at the VCR), it should then power up and work properly.Google is your Friend
	You can also try leaving the VCR unplugged from AC for several minutes to see if that resets the microprocessor.
	I had a similar if not exact JVC unit. The power supply would go out yet the light(s) would come on. I replaced the PS 3 times before it went out again. I remember throwing it away. I'd had enuf.
  The "auto heal" tool in adobe audition cs 5.5 is too much aggressiveBy gil900 in forum AudioReplies: 8Last Post: 7th Jul 2015, 21:27
  [SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyintBy Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21
  Samsung LCD TV 32" fullHD won't turn onBy dzsoul in forum DVB / IPTVReplies: 73Last Post: 16th Nov 2013, 09:52
  How do you turn on/off "write protect" on BD-RE ?By piano632 in forum MediaReplies: 3Last Post: 27th Apr 2013, 23:00
  How to disable "automatically turn off screen" when I open a software?By Anonymous847344 in forum Capturing and VCRReplies: 2Last Post: 18th Apr 2013, 01:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
