I originally had some videos in x264 format, and I converted them to x265 format using StaxRip, but I forgot to join the files together before I did it. These files are from my action camera, and are basically where the camera saves one file, and continues recording to another. I generally have no problems joining them when where in x264 format using the "copy" function of Avidemux, however Avisemux is crashing when I try and do it with the converted files. I get "Assert Failed: avformat_write_header(oc, &dict) >= 0 at line 121, file /home/fx/hudso.......... The application has encountered a fatal problem" I then click ok, and get a Visual C++ Runtime error. Then I click OK and the program closes.
I am assuming that Avidemux isn't advanced enough to join x265 files without re-encoding? If that is correct, what can I use to join these files?
Either way, how can I resolve this, without re-encoding the files?
If the x265 settings are the same you should be able to join them in latest mkvtoolnix gui using append file option.
Avidemux Help required for Joining
By kabiraftab in forum EditingReplies: 10Last Post: 9th May 2016, 16:51 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 07:14 -
Error deinterlacing to encode videos in Avidemux?
By dandorf in forum Video ConversionReplies: 2Last Post: 26th Apr 2015, 10:44 -
Cut joining mp4 Avidemux WHY can't it go right?
By angles in forum EditingReplies: 4Last Post: 21st Apr 2015, 13:56 -
Avidemux crashing for no obvious reason
By pooksahib in forum Newbie / General discussionsReplies: 6Last Post: 30th Jul 2013, 15:43
