ok i dont know what technical words should be used in this process...
its like i have some collection of videos and in mostly all vids it have some audio/speech ,which plays in between the vids for 2sec .. its like "for more tuts download from so and so blog"... now at what duration does it play thats hard to find as the vids r some 40mins and even 1 hr long :/
It taking too much time to catch that 2 sec voice in whole video.. plz help in this.. thanks
If there's a few moments of silence before and after the '2nd audio' plays,
you might be able to spot it using an audio editor like the freeware Audacity.
Assuming Audacity can open the video, you may see and be able to playback,
extract or replace the audio with silence, depending on your preferences.
It would be easier if you have a general timeline idea where each of the audio additions are, to reduce searching.
But others here may have a better idea.
Post a 30 second sample that includes the part you want cut out in the middle.
It may be possible but without a example showing what you're looking for it's all just theoretical. If you can't be bothered to find a sample and provide it nobody here is going to spend their time writing a book on how such things might be done.
Prithvi, I suspect you are asking for an automated process to find those speech sections. It does not exist my friend. You will have to do it the old fashioned manual way by finding each one and editing it out.
Suggestions for some voice changing software for cartoon voice-overs?
By dilophosaurus65 in forum AudioReplies: 0Last Post: 15th Mar 2017, 17:03 -
Video exported with pinnacle16 :image plays then freezes audio plays fine
By RonWolpa in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2015, 18:00 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 21:12 -
extracting dubbed voice from a audio
By Tri P in forum AudioReplies: 7Last Post: 11th Nov 2014, 12:44 -
Enable audio stream switch only default one is displayed, 2nd audio missing
By Fproviders in forum Video ConversionReplies: 5Last Post: 2nd Nov 2012, 18:25
? friend if i know that particular part (where that 2nd audio plays), then i would have done it by my own.
