Hi..
I use CRF for encoding and most to the times video output turns to be good but 2/10 video encodes get like really low bitrate and the quality turns out to be really bad. so i want to set minrate for a video...
Like whatever the encode is the video bitrate should not be lesser than 500kbps but not sure how to achieve that. I was going through x265 documentation and found out about --vbv-bufsize and --vbv-maxrate.
I want to use minrate instead of maxrate. Is it possible to do so? if yes what will be bufsize?
Handbrake increase vbv-maxrate ?
By Hanted in forum Video ConversionReplies: 0Last Post: 31st May 2017, 10:19 -
Video codecs in relation to file size
By Encodito in forum Newbie / General discussionsReplies: 4Last Post: 3rd May 2016, 20:18 -
Latency in relation with and its impact on bandwidth
By vhfu in forum Video Streaming DownloadingReplies: 3Last Post: 12th Mar 2014, 14:19 -
how is maxrate used in FFMPEG when converting?
By hxuanyu in forum Video ConversionReplies: 0Last Post: 8th Sep 2013, 19:20 -
ffmpeg using crf and bufsize
By wotdefcuk in forum Video ConversionReplies: 10Last Post: 15th May 2013, 12:52
