WASSUPPII! Hi guys. I need some helpful pointers here. I have a movie on my HD in .AVI and also the sound file in .AC3. I am trying to convert it to .MPEG and have had success in the conversion. The thing is that when I go to watch it, it tends to start to repeat itself about 1/8th the way through it. Don't get me wrong here, it doesn't stop and repeat itself on through infinity. No. Instead, it will stop at one point, repeat itself for a few frames, (along w/ sound), then go on for a few frames, then stop again and repeat a few frames. It will do this through the rest of the movie too. I need some serious help here, but any help would do just fine. By the way, the movie is about a hacker who saves the world in the real world. Hint, hint. ( I didn't know if you needed to know which movie it was or not...) Thanks!
With his senses keen, don't fail to watch your back. For when the time is right, Wolf will be there for the final attack...
can someone help me in encoding avi to vcd format (mpeg)
1) i used v-dub to extract the audio as a wav then saved it
2)went in tmpenc and coverted the avi to mpeg input the wav file as audio
3) encodin went fine using tempenc --NO errors
4) then i tried to play the mpeg file in media player but only the audio worked no video (black SCREEN)
any suggestions -
Hijacked thread!
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
