I captured the following:
TAPE02-FULL
4h 4m | 40.5 GB
720*576 (5:4) | 22.2 Mb/s | 25 FPS | Canopus HQX (PAL)
1,536 kb/s | 48 kHz | 16 bits | 2 channels | PCM (Little/Signed)
TAPE03-FULL
1h 6m | 9.90 GB
720*576 (5:4) | 17.7 Mb/s | 25 FPS | Canopus HQX (PAL)
TAPE04-FULL
3h 3m | 31.5 GB
720*576 (5:4) | 23.1 Mb/s | 25 FPS | Canopus HQX (PAL)
TAPE05-FULL
2h 3m | 20.9 GB
720*576 (5:4) | 22.8 Mb/s | 25 FPS | Canopus HQX (PAL)
Clearly 102 GB is too much for anything other than archival.
Which format, bitrate etc. would you compress these VHS rips at?
What happened to Tape01 ?
But seriously the real questions ere 1. How and where you intend to view these tapes. 2. Do they need any post-processing (Noise removal etc.)
And you really should archive the captures should you decide at a later date to convert to another medium. -
Well, now, since you already capped noisy wobbly fuzzy VHS to artifact-laced mosquito noisy lossy DV, why don't you just encode them to h.264 with the cheapest software you can find (free is best, and there's plenty of it. Try Avidemux), and the lowest bitrate you'd like to live with? Why is this a question?
- My sister Ann's brother
StaxRip template for VHS rips
By iEncode in forum Capturing and VCRReplies: 23Last Post: 17th Jul 2014, 16:27 -
Need Help Choosing Capture Card, TBC, and Software/Settings for VHS/8mm VHS
By Duder_Me in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2014, 10:42 -
Audio settings for SD & HD Rips
By MikeC58 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Apr 2014, 21:28 -
Recommended settings to compress lecture from WAV to MP3?
By yetanotherlogin in forum AudioReplies: 4Last Post: 29th Jan 2014, 15:48 -
handbrake best settings for compress
By tomsta79 in forum EditingReplies: 4Last Post: 22nd Sep 2013, 07:33
