Hello.
I noticed, that a DVD drive, which struggles with unreadable sectors on a CD, always gets unresponsive, and affects the performance of the whole PC, until the drive is switched off or the eject button is pressed.
Can anybody explain this? Why does that happen?
I don't understand the technicalities, but is it more likely to effect the performance of the whole PC when you're doing something that requires navigation via Explorer? A program's File/Open menu, or saving files, for example? It can be annoying anyway if a DVD drive has a disc in it even if it's doing nothing, because the process will probably stall while the drive spins up and reads the disc etc, but when a drive is in the middle of an anxiety attack sometimes everything does come to a halt until you hit eject to make it give up.
I have three DVD burners in this PC. Three different models and two different manufacturers and I'm pretty sure they're all prone to it, but generally a drive can moan and groan for hours without effecting the PCs performance as long I don't initiate a task that requires it to participate in some way.
DVD Drive Class action suit $10 per drive
By stiltman in forum Latest Video NewsReplies: 0Last Post: 7th Feb 2017, 14:56 -
Data Recovery Software For Unresponsive Xternal Hard Drive
By Frank-0-Video in forum ComputerReplies: 3Last Post: 22nd Feb 2015, 19:04 -
Dvd freezes!!!
By paulg19_84 in forum Newbie / General discussionsReplies: 17Last Post: 30th Mar 2014, 05:13 -
Burnt DVD Freezes
By Erik419 in forum Newbie / General discussionsReplies: 12Last Post: 6th Mar 2014, 14:40 -
Batch video conversion: Windows becomes slow/sluggish/unresponsive
By Stoic18 in forum Video ConversionReplies: 7Last Post: 18th Apr 2013, 12:00
