Is it possible to create a VCD with subtitles you can turn on/off (like a dvd)? What about in an Svcd?
Hi,
Yes/No. I have some original VCD's (And i mean really original) that have the ability to turn on/off subs. Problem being.... this only works on CD-I players. So the subs are probably a piece of software that run on CD-I compatible machines only.
It doesn't work on my NAPA VCD player, nor my Amaisonic DVD player. Even my PC is unable to view these subs.
So, if you could ever get your hands on a piece of software that is capable of burning such subs, you probably won't be able to view then on anything else than an old CD-I player
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
You can do this with svcds and play it on a dvd player but not all dvd players support it. According to the svcd standard you can have up to 4 separate sub streams.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
