Sounds like a bitrate problem. Usually your PC can handle higher bitrates than a standalone DVD player. Maybe it's best to stick to the VCD or SVCD standards by using the templates in TMPGEnc. It's likely that your DVD player is designed to play only VCD (and maybe SVCD) compliant Mpegs. You can check the DVD player compatibility list on the left for more info on your player, or you may add your findings to this list after you've done some experimenting.
Regards,
Willem -
usually the best way to solve this is to use virtualdub to save the audio from the avi into a wav file.
then, in tmpgenc you select the video source like normal, but select the wav you just created as audio.
viola! you get a nice mpeg with sound and all. this applies for vcd, you talked about dvd format but my guess is that youo don't have a dvd burner. or do you?
my PC lost sound.
By volam1 in forum AudioReplies: 8Last Post: 9th Dec 2009, 04:37 -
Lost sound with .mod format
By mudracer-1 in forum Software PlayingReplies: 4Last Post: 6th Apr 2009, 22:50 -
avi to dvd lost sound
By makapa in forum Newbie / General discussionsReplies: 3Last Post: 2nd Feb 2008, 06:11 -
Lost Sound
By airgunforum in forum EditingReplies: 3Last Post: 22nd Nov 2007, 10:40 -
Lost sound on Pinnacle Studio 10 on PC.
By Balliol in forum AudioReplies: 0Last Post: 17th Jul 2007, 18:25
