Hi,
Very new to screen capturing and I;ve recorded a video for uploading to Youtube and at the start it's blurry and then comes into focus half way through - does anyone know why this is?
I exported the video as an mp4 and recorded at 1080p, I then put it into a Video Editor and saved it as a HD Video for Youtube (1080p).
Should probably give an example, the video is here - https://www.youtube.com/watch?v=tmFGKPhrM-g&feature=youtu.be
Most likely a download buffering issue during playback.
Once it goes clear, start replaying by moving the slider to the beginning. Does it still look bad? -
Just tried doing that and it;s still blurry and becomes clear at the same point.
It doesn't look that "blurry" to me at the beginning
Which browser?
Which stream are you watching ? Did you make sure to select 1080p HD ? It might be that you have it on "auto" and it begins with a lower quality SD stream before switching -
Highest available format (1080p) is sharp from first frame - download video locally - seem it is 2.2MB size.
Best codec + settings with no pixels/blurriness/saturation?
By Jirachi in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2016, 00:46 -
mkvmerge gui crashes on start/won't start
By buck09 in forum Blu-ray RippingReplies: 7Last Post: 1st Nov 2015, 23:43 -
How to merge videos that start at different times?
By Chibears85 in forum EditingReplies: 3Last Post: 2nd Aug 2015, 19:35 -
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
How to eliminate jumps and blurriness in Youtube videos?
By Bencuri in forum Video Streaming DownloadingReplies: 4Last Post: 2nd Jan 2014, 14:14
