This is a question I got asked many time since I recently got an AAXA M6 and showed it to my friends. They were impressed by its performance and started showing interest in buying one. I have some opinions but would want to hear the voice from more people. Thus, I am starting a thread here.
My consideration: brightness, resolution (not just look at the number. It would be better to check the video/image quality in store to make sure you like what you see), portability (I need one that I can carry while traveling. But it's not a necessity for all).
What else would you consider? let me know your thought!
Size of projected video at the selected distance from the screen is important to me. Some have zoom.
Keystone adjustments if your projector sits below the centerline of the screen.
And the types of formats it can handle and the types of video connections it uses.
Not so much about the projector, but the type of projection screen can also influence quality. A screen made just for video can help.
Contrast or black level ratings to get a better quality picture.
And resolution is important, depending on the video. My projector is 1920 X 1080 as I don't have any 4K types of video at present. -
Price.
Lumens & brightness output per square meter (at thrown distance)
Longevity of that rated output
Mtbf of lamps & unit as a whole (expected lifetime)
Color purity & full spectrum saturation at full rated output.
If doing text output, 1:1 scaling mode
Hdcp compliance.
If you are into it, 3d capability.
Weight.
Heat generated.
How is it mounted? Accessories needed?
Hardware and Software Purchasing Help Needed for New Project
By OriginalEGG in forum Newbie / General discussionsReplies: 13Last Post: 17th Dec 2015, 18:15 -
Is it possible to skip the activation screen in DVDFab after purchasing?
By premiumcapture in forum Video ConversionReplies: 1Last Post: 31st Mar 2015, 23:06 -
Need help purchasing equipment to record interviews/panels
By Shamohelp in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2014, 16:04 -
Need Help (Advice) on purchasing a BR-Drive, Burner
By noobish in forum Blu-ray RippingReplies: 21Last Post: 11th Oct 2013, 07:44 -
Does purchasing the Windows 8 Pro Upgrade Invalidate old OS license
By KTH in forum ComputerReplies: 13Last Post: 9th Jan 2013, 14:04
