    Sep 2017
    Bahrain
    Hi
    I have a bunch of XML+PNG subtitle that I need to convert to IDX to be able to play them on my WDTV. How can I do that ?
    and what video player software support XML subtitles on PC? I'm using MPC and VLC and both doesn't seem to recognize the subtitles !
  2. BDSup2Sub (For a bunch there's CLI)
    Subtitle Edit: Drop the XML onto Subtitle Edit. In the OCR window Rightclick -> Export -> Vobsub
    Sep 2017
    Bahrain
    I've already tried BDSup2Sub and this is the Error message that I get
    Sep 2017
    Bahrain
    And this message when using subtitle edit
    Is there a problem with the subtitle files ?
    HTML Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
       at Nikse.SubtitleEdit.Forms.ExportPngXml.GeneratePreview()
       at Nikse.SubtitleEdit.Forms.ExportPngXml.previewTimer_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    SubtitleEdit
        Assembly Version: 3.4.3.0
        Win32 Version: 3.4.3.0
        CodeBase: file:///C:/Program%20Files/Subtitle%20Edit/SubtitleEdit.exe
    System
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Configuration
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Sep 2017
    Bahrain
    This is one of the subtitles I have
    can someone check and tell me what I should do to convert it ?
    https://files.videohelp.com/u/271723/EP%2001.zip
  6. The problem is the format of your XML.
    Download XMLConverter.7z here https://forum.videohelp.com/threads/365786-Converting-Subtitles-(XML-PNG)-to-idx-sub and convert your XML to BX-SR035460-ARA-ARA_adjusted.xml and use that in BDSup2Sub/Subtitle Edit
  7. why sub/idx? use SUP is better
