Results 1 to 9 of 9
    Sep 2017
    Hi,
    I have seen that there is youtube software for downloading youtube video's but does anybody know of any software to find the url of a youtube live video??
    if you put the url of a live youtube video in vlc player it just freezes
    example : the url for al jazeera news is https://www.youtube.com/watch?v=WAt9ZT2CQWg, if you put this address in vlc it will freeze.
    Any help will be much appriciated.
    Many thanks
  2. Maybe somebody can come up with a better idea. You can record the live stream with this (but cannot watch while downloading):
    youtube-dl -f 93 https://www.youtube.com/watch?v=WAt9ZT2CQWg
    You can pipe the stream into vlc using this:
    youtube-dl -f 93 https://www.youtube.com/watch?v=WAt9ZT2CQWg -o - | "C:\Program Files\VideoLAN\VLC\vlc.exe" -
    However, when you do that, then youtube-dl doesn't simultaneously save to a file.
    If you press the red record button on vlc while the video is playing (see screenshot, red circle) , then vlc will record the video to a file.
    Even though the video as watched in vlc may start/stop/pause/resume, the recorded vlc file should play perfectly. Something seems strange, though because the command line shows I was downloading at about 10fps, so it seems that some video would be lost in the vlc recording.
  3. Sometimes you can play the video file while it is downloading (eg, use VLC to open the file that youtube-dl is saving) but it doesn't work for this video.
  4. I thought there might be a way to pipe the video to ffmpeg and have ffmpeg remux to a .ts file that could be played while the video was still downloading.
    youtube-dl "https://www.youtube.com/watch?v=WAt9ZT2CQWg" -o - | "G:\Program Files\ffmpeg\bin\ffmpeg.exe" -y -i pipe:0 -c copy -f ts output.ts -
    But I couldn't get it to work. ffmpeg complains about the container not being suitable for the streams:
        Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DA
    R 16:9], q=2-31, 30 fps, 30 tbr, 90k tbn
        Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, 129 kb/s
    Stream mapping:
      Stream #0:1 -> #0:0 (copy)
      Stream #0:0 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    Input #0, mpegts, from 'pipe:0':
      Duration: N/A, start: 1.400000, bitrate: N/A
      Program 1
        Metadata:
          service_name    : Service01
          service_provider: FFmpeg
        Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progress
    ive), 1920x1080 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 90k tbn, 60 tbc
        Stream #0:1[0x101]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 123 kb
    /s
    [NULL @ 034375e0] Requested output format 'ts' is not a suitable output format
    output.ts: Invalid argument
    av_interleaved_write_frame(): Broken pipe
    Error writing trailer of pipe:: Broken pipeframe=  156 fps=0.0 q=-1.0 Lsize=    2437kB time=00:0
    0:05.20 bitrate=3835.3kbits/s speed=29.3x
    video:2163kB audio:85kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 8.448
    796%
    Conversion failed!
    I'm probably doing something wrong here but I don't know ffmpeg well enough to figure it out. I tried other containers like m2ts, mkv, mp4 and got the same error.
  5. Originally Posted by jimdagys View Post
    What does -f 93 in the link mean?
  6. Originally Posted by Sounds;2498865What does [B
    -f 93[/B] in the link mean?
    It's the id of the particular stream you want to view/stream. To see a list of the available streams use:
    youtube-dl -F https://www.youtube.com/watch?v=WAt9ZT2CQWg
    Note the capitol F rather than lower case f.
    prompt>youtube-dl -F https://www.youtube.com/watch?v=WAt9ZT2CQWg
    [youtube] WAt9ZT2CQWg: Downloading webpage
    [youtube] WAt9ZT2CQWg: Downloading video info webpage
    [youtube] WAt9ZT2CQWg: Extracting video information
    WARNING: unable to extract uploader nickname
    [youtube] WAt9ZT2CQWg: Downloading m3u8 information
    [youtube] WAt9ZT2CQWg: Downloading MPD manifest
    [info] Available formats for WAt9ZT2CQWg:
    format code  extension  resolution note
    91           mp4        256x144    HLS  197k , avc1.42c00b, mp4a.40.5@ 48k
    92           mp4        426x240    HLS  338k , avc1.4d4015, mp4a.40.5@ 48k
    93           mp4        640x360    HLS  829k , avc1.4d401e, mp4a.40.2@128k
    94           mp4        854x480    HLS 1380k , avc1.4d401f, mp4a.40.2@128k
    95           mp4        1280x720   HLS 2593k , avc1.4d401f, mp4a.40.2@256k
    96           mp4        1920x1080  HLS 4715k , avc1.640028, mp4a.40.2@256k (best)
  8. Hi all ,
    Below my try
    livestreamer "https://www.youtube.com/watch?v=WAt9ZT2CQWg" best -o Try_18102017.mp4
    Try_18102017.mp4 is watchable with MPV
    Cheers .
    JE SUIS CHARLIE !!!
  9. does this allow to start recording YT live videos? Like those never ending chill out music for studying videos?
