I've got a couple of very old videos in WMV format , probably shot in early 2000 , they are in very poor quality. I would like to remaster them and upgrade their quality a little bit. Is it really possible? and how to?
	You can fix some problems. You can fix brightness, contrast, and colors. You can sharpen a little, though that may enhance compression artifacts already in video. You can reduce blockiness (but in exchange you'll get blurriness). You can reduce some types of noise but that may cause posterization and motion artifacts. It all depends on exactly what's wrong and how wrong.
	A lot depends on the problems with your old video. I worked on a video from the very first days of digital video, around 1992. It was only 12 frames per second and 160x120. I was able to make it look much better by smoothing out the block noise and increasing the frame rate using motion interpolation. The result was much more watchable. You can read this old thread about it:
 Restoring Early Digital Video
 The actor featured in the clip, Goeffrey Lewis, died last year.Last edited by johnmeyer; 5th Sep 2017 at 08:18.
	This may be helpful
 https://forum.doom9.org/showthread.php?t=134078
	Cartoons and Anime are a bit of an exception. They have large flat shaded areas and simple black outlines. Those are more easily repaired.
  Looking to upgrade computer monitor for video editingBy vhelp in forum ComputerReplies: 22Last Post: 16th Nov 2016, 07:11
  Improve blurry low quality video into clear high quality video.By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 02:48
  Will video processing benefit from a card upgrade.By sambat in forum Video ConversionReplies: 3Last Post: 9th Oct 2014, 00:17
  Video/Photo editing upgrade?By beavereater in forum ComputerReplies: 10Last Post: 19th Sep 2014, 10:38
  premiere 6 upgrade, section of project missing after upgradeBy krohm in forum EditingReplies: 0Last Post: 9th Jan 2013, 23:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
