I have been using Sefys newbie guide with very pleasing results (thanks Sefy) But now I have come accross a problem with Fantasia,the audio seems to be missing I tried some of the solutions in a previous post to no avail. After ripping the movie I do have sound on the vob files so its not in smart ripper.I have tried changing some settings in tmpgenc but nothing. Please help
Steve
i'm assuming when you created the project .d2v file in dvd2avi, there was no .wav file.....
in this case, in dvd2avi, goto audio->track and select a different track...to make it easier, once u've selected another track, press f5 (preview) and look at the info box
in the info box, look at the audio info, dvd2avi only decodes DD, so if the audio track is blank, then choose another track and repeat...after u've selected the track u want, u can then create the project file
make sure you play the .wav afterwards w/ mplayer b4 u encode (make sure it's the language u want, if not choose another track and try again) -
Right on the money
And if you get the latest DVD2AVI 1.76 Build 1.86 it can now handle DTS!Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
