So I've been using this unit to archive my VHS with great quality but it's suddenly begun eating my radios. I made a YouTube video in the hopes that this might be something I can fix myself. Whenever I try to eject the cassette, the tape does not thread back through the cassette.
Anyone have any suggestions?
https://www.youtube.com/watch?v=nTxaqBqkylA
Results 1 to 16 of 16
Your take-up reel drive belt is probably slipping or broken. The belt may be available at fry's or you can use a rubber band to replace it.
The video shows that the takeup reel turns fine in Play mode so the belt is working. The problem is that the supply reel is not pulling in tape during unload. It twitches just a bit and then stops. So there is a problem with the idler gear, or the idler lever, or the clutch, or the control cam.
Sounds like the capstan belt fell off or broke,never use a rubber band to replace,always use a replacement belt.
Take the bottom cover off and see if any belts are off/broken.
Again, if the belt were broken, the takeup reel would not turn. And it does turn.
To diagnose, you really have to take out the mechanism and main board as detailed in the service manual, then install a temporary jumper that permits the mechanism to go through every mode without a cassette loaded. Otherwise, you can't see what's happening with the idler.
You didn't answer my question about FF and Rewind. -
Sorry for the delay. It's been a truly hellish work week. I checked FF/REW and FF works properly but REW makes the unit shut down. Also, stop/eject now seems to be working properly. The tape threads back into the cassette to eject. Clearly that doesn't mean the problem is fixed, by any means. I'm just throwing it out there.
So there's no doubt that your supply reel is not being driven consistently. The idler gear is supposed to flip over to the supply side, mesh with the spindle gear, and turn. You can make a cheater cassette to see what's going on. Take out the reels, cut windows in the top and bottom and cover the side holes that are revealed when the door is open.
I did get a response from James Rattazzi @ rattazzitech.com and he said he knew exactly what to do. It's $100 for an in-home fix.
Check on Youtube for repair videos for your deck. Might be a lot cheaper than you think to repair. Been doing well with 12voltvids and others for repairing my old Betamax units...
12voltvids are pretty great, but you still need to have an array of tools, mechanical aptitude, and lots of patience. Plus a lot of time when you are a beginner. Hopefully, you will also be a heck of a lot neater than 12voltvids; his workshop floor must be covered in bits of things he lets fly off into space.
You need to replace the idler assembly, the the gear and lever in the center of the reels. You can get it at http://www.searspartsdirect.com/model-number/HRS9800U/1758/0334000.html. I would also replace the belt as well. I did TV - VCR work for 30+ years until I retired.
JVC VCR Repair Service 7000 & 9000 Series & Professional Line
By Deter in forum RestorationReplies: 9Last Post: 24th Apr 2023, 07:21 -
Successful passthrough repair of vcr tearing with a Pioneer DVR
By liddle in forum Capturing and VCRReplies: 3Last Post: 25th May 2015, 23:40 -
Problem with JVC HR-S9800U VCR
By jdmack in forum Capturing and VCRReplies: 14Last Post: 7th Nov 2013, 12:43 -
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 555Last Post: 1st Jul 2013, 12:33 -
JVC HR-DVS2u vs HR-S9800u
By braxus in forum DVD & Blu-ray RecordersReplies: 3Last Post: 29th Jun 2013, 19:53
