  1. Member koberulz's Avatar
    Oct 2006
    Australia
    I've authored a Blu-Ray disc in DoStudio, which displays the loading screen and then freezes. Not a clue where to look for solutions.
  2. Member DB83's Avatar
    Jul 2007
    You will be most fortunate to find anyone in these forums who has used this s/w. It really is for pros and the price charged highlights that.
    Even then, why are you using it ? It is no longer supported and if you are using the trial version it would be useless after that time since it is also no longer sold.
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    I bought it a couple of years ago. It works for me, I know how to use it (99% of the time, at least...), and I don't have the budget for anything with the same features.
