Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or buy Replay Video Capture or PlayON and record Netflix, HBO, etc! :)
    Jan 2014
    Western Arkansas
    I bought two 50 disc spindles of Verbatim 8xDVD+R DL that are ink jet printable. These will not write to the second layer using imgburn. My DVD burner is in my Dell laptop and is a DU-8A5LH. Dell says I have the latest drivers etc for all my devices. What can I do?
    Feb 2006
    How big is the movie file you are trying to burn ??
    Also see this thread - https://forum.videohelp.com/threads/384919-Layer-Break-error-when-burning-with-ImgBurn
    Jan 2014
    Western Arkansas
    its not a layer break error. I can see several break points to choose from when I set it up.
  4. Member DB83's Avatar
    Jul 2007
    The first thing you try is a different break point and....
    Do not write at the maximum speed for your media. You should write at no more than half-speed so that means 4x for you.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    bad drive, oversize image or fake discs? hard to tell the difference.
    Jan 2014
    Western Arkansas
    cut down to 4x write speed, different break point and a different brand disk. Writes to layer 0 with no problem but as soon as it tries to write to layer 1 it fails.
  7. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    jc8952, , please do not double post. I've deleted the other post. If you want to move a topic to another forum, PM a Mod.
    Moderator redwudz
    Jan 2014
    Western Arkansas
    sorry. I didn't mean to.
    Thanks for the comments folks. I think my DVD burner is kaput. I tried these discs on another computer DVD burner and they worked fine.
