Lately, I've encountered SD video captures that are in 512 X 384, and with my VLC player set to play them at native resolution, the video is smaller than it is for stuff that plays at 640 X 480. I'm guessing that the whole 512 X 384 idea comes from some sort of calculation that says 384 is enough to capture all vertical detail, and they then set the horizontal to 512 just to keep the 4:3 aspect ratio? If I resize it to 640 X 480, does that cause a loss of video quality through scaling? I'm not great at judging what is more "accurate."
I see in the video help section that the recommendation was 352 X 480 for SD analogue broadcast captures.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
This is very large topic so to be short - if you really must re-size source video go with some even factor if even is not possible then odd factor may be acceptable however try to avoid fractional factors - in other words enlarge your video by 2 - from your perspective perhaps resize on display without resizing source will be ok? configure your player in a way that video is rescaled on the fly whenever played .
Any time you scale a video you lose quality.
Any time you reencode a video with a lossy codec you lose quality.
Of course, depending on how you do it the loss may not be very visible.
512x384 is just an arbitrary 4:3 frame size. Someone may have used a program that uses a compromise of frame size vs. file size.
TrueHD/AC3 question (384 core) need 640 ac3
By PatrickBatman in forum Blu-ray RippingReplies: 16Last Post: 31st Dec 2015, 17:10 -
1920 x 1080 vs 640 x 480
By taxidriver in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2014, 12:15 -
Problem in 640-480 OR Higher resolution with Pinnacle PCTV 150E/55E
By arshadsheikh.in in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2014, 12:08 -
How do I keep my videos in 480 x 480 reso?
By kyharr96 in forum ComputerReplies: 9Last Post: 28th Aug 2013, 23:54 -
640 x 480 to DVD
By santiam in forum Video ConversionReplies: 18Last Post: 7th Jun 2013, 12:11
