Hello everyone, I installed CCE 2.64 plugin not a stand alone program. When I try to export time line and use options VBR 3 pass, CCE says it can process audio with VBR. How can I solve this problem so it export audio as well rather than video only. Thanks
cce sp does not create a system stream in VBR mode. You will end with seperate video and audio files. After conversion multiplex these files with bbMPEG or TMPG to a MPEG system stream.
Do you know where I found templates for premiere with this plugin or where I found a good guide for the plugin ?
TanksR@C@N@
cana51@hotmail.com.br
Is there a software or plugin?
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2011, 21:43 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
The Best Video Plugin Ever!!
By DemonSeed in forum Media Center PC / MediaCentersReplies: 20Last Post: 18th May 2009, 13:59 -
vegas plugin
By wingfan in forum EditingReplies: 5Last Post: 10th Nov 2008, 10:33 -
quicktime plugin
By geonuine in forum Video Streaming DownloadingReplies: 7Last Post: 17th Jul 2008, 20:38
