So here it is, GCC 7.2.0 for the MSYS2 environment.
Again, the file os_defines.h in the source-code was modified so that ffms can be safely added to the 64-bit editions of x264.exe.
I tested the new compiler against L-Smash, and everything went fine.Code:#ifdef __x86_64__ #define _GLIBCXX_LLP64 1 #define _GLIBCXX_USE_WEAK_REF 0 #endif
It's interesting that GCC 7.2 took "only" 1 hour and 39 minutes to be compiled on my ancient quadcore...
GCC 7.1 required 2 hours and 15 minutes (ouch).
AnonymousGuest
Tried to use 7.2.0 in rdp's ffmpeg build script ... well, so much for that
both of these
result in stuff like the below. Suggestions welcomed on what the error message means.Code:download_extract "http://ftp.gnu.org/gnu/gcc/gcc-$gcc_ver/gcc-$gcc_ver.tar.xz" "ftp://ftp.gnu.org/gnu/gcc/gcc-$gcc_ver/gcc-$gcc_ver.tar.xz" download_extract "http://ftp.gnu.org/gnu/gcc/gcc-$gcc_ver/gcc-$gcc_ver.tar.gz" "ftp://ftp.gnu.org/gnu/gcc/gcc-$gcc_ver/gcc-$gcc_ver.tar.gz"
Of interest, 7.1.0 works ok.Code:[32/55]: Extracting gcc-7.2.0.tar.gz... pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory ...
AnonymousGuestWeird, to say the leastOf interest, 7.1.0 works ok
Still, I don't see what the choice of a different version of GCC would have to do with the extraction of a downloaded archive
BUT, and FWIW:
The .TAR.xz archive that contains the source-code of GCC 7.2 is different from the previous ones.Code:[32/55]: Extracting gcc-7.2.0.tar.gz... pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory pax: Unable to create gcc-7.2.0/libstdc++-v3/testsuite/25_algorithms/stable_partition/requirements/explicit_instantiation/: Is a directory ...
It does contain a "Pax.header" file that confuses my old 7-Zip (v. 15.12) and my old WinRAR (v. 5.31) as well
I had to use the tar.exe from my (somewhat old) MSYS2 environment for extracting the contents of the archive without errors
(namely, the creation of duplicate files (or directory entries) and even a con file that cannot be erased by Windows itself
— I had to use WinRAR to rename the invalid file and thus remove the directory tree in which it was inserted).Last edited by Marsia Mariner; 3rd Sep 2017 at 11:34. Reason: clarity
something along these lines seemed to work
where gcc_ver contains string "7.2.0"Code:tmp_gcc_ver=${gcc_ver//./_} # eg 7_2_0 # ${string//substring/replacement} Replace all matches of $substring with $replacement. set -x svn checkout svn://gcc.gnu.org/svn/gcc/tags/gcc_${tmp_gcc_ver}_release gcc-"$gcc_ver" echo "tmp_gcc_ver = \"${tmp_gcc_ver}\"" cd gcc-"$gcc_ver" svn update cd '..' set +x -
AnonymousGuest
Not so off-topic...
source: https://github.com/rdp/ffmpeg-windows-build-helpers/issues/259Originally Posted by DeadSix27
Compiling GCC 5.5 and 6.4 this time... with 5.5 everything went fine, but with 6.4 the «pax trouble» strikes again.
Again I had to extract the .tar file with 7-Zip and unpack it with tar.exe itself.
I had never heard of "pax" until I decided to compile GCC 7.2...
Typical *nix+FOSS stubbornness, sadly.
GCC 7.1.0 for MSYS2
By Marsia Mariner in forum ComputerReplies: 3Last Post: 25th May 2017, 17:13
