hi everyone,
i'm sure this has probably been asked before, but please forgive me as i am a "newbie" to this forum. here's my problem... i'm having trouble making video cds out of my "The Critic" data cd. the data cd contains all 20-something episodes, each in RM format. i visited this webpage and followed the directions to convert the files using EO Video and TMPGE. after i finally got the conversions done and burned a vcd (with nero) containing the 3 episodes i converted, i put the vcd in my dvd player and...success!!...well, not quite, and here's where i need advice...the video and the audio start out pretty much in sync, but after about a minute or two, they start to fall noticibly out of sync...after about 10 minutes, it's almost completely unwatchable because of the delay between the audio and the video...i have a few theories: not having a separate hard drive as a scratch disk, wrong video settings (should i "maintain aspect" or "fit to size"?), should i try converting to another format before burning the vcd, etc.... ok, that's the end of my long winded story... :-) any help from the pros would be quite appreciated.
thanks!!
-joe
Chances are that when you encoded the rm files in EO Video, you did not choose the correct frame rate.
Re-syncing Audio/Video: Utility Recommendations?
By will7370 in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2012, 08:24 -
help syncing audio .wav of music to video of musician
By tspnyc in forum AudioReplies: 6Last Post: 1st Dec 2010, 17:27 -
Newbie here needs help syncing audio to video
By blackwaterstout in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2010, 07:19 -
Visually Syncing Audio with Video
By gonzalu in forum EditingReplies: 11Last Post: 17th Mar 2009, 19:18 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14
