hi there
I have upgraded my PC from windows 8.1 to windows 10. But after upgrading i cannot open one mdb extension file which was on my flash drive.
getting a message saying 'Unknow error'.
i could open it before
any thoughts please?
Do other flash drives work OK? And do you have MS Access/Office installed and does it work OK with W10 otherwise?You may need a update of Office to work with .mdb files with W10. Some other info about .mdb: https://www.lifewire.com/mdb-file-2621974
I haven't used Access in some time. Or you can also open them with the freeware Open Office that performs similar to MS Office.
https://www.openoffice.org/
But we likely have some members that are more familiar with Access and .mdb files.
And welcome to our forums.
As the .mdb file you are using might have been corrupted. So you may use MS Access option to Compact and Repair. to repair your database.
If this unable to repair your database you may try to find info here http://www.erepairaccess.com/ to repair mdb database.
Preview version is free. So you may try. Hope this helps you.
DVD burns Freezing / Pausing since upgrading to Windows 7 (x64) Ultimate
By Wilf_12 in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2015, 04:27 -
Problem videos - After upgrading to Windows 10
By razielraz in forum Newbie / General discussionsReplies: 4Last Post: 15th Aug 2015, 08:32 -
Upgrading madvr
By victord66 in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2014, 06:21 -
upgrading audio quality
By aruwin in forum AudioReplies: 5Last Post: 5th Oct 2013, 09:11 -
Are you upgrading to windows 8?
By johns0 in forum PollsReplies: 45Last Post: 30th Sep 2012, 11:10
