Hi, right now I'm using handbrake to convert an old anime serie, my source files don't have chapters and I know that handbrake cannot create chapters from scratch, but you can import csv or tsv files.
Now, since all episodes have the same structure, I'll just need to make a simple csv file with three chapters: chapter1 = 00:01:36:000; chapter2 = 00:12:20:500; chapter3 = 00:23:01:000
How can I do it? Is there somewhere where can I download a .csv example file and modify it to suit my needs?
Thank You.
AFAIK the import is only for re-naming existing chapters, not add chapters to a source that doesn't have any in the first place.
Are you using mkv or mp4 output? Mkvtoolnix can add chapters to mkv files. -
You were right, I tried to do what I proposed in the OP but hanbrake just saw one chapter, I could rename it, but that's it.
I solved with Drax: you have to do the video files one by one, but luckily you can export/import chapter files (in .txt format).
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 08:19 -
Bluray Authoring Programs Without Chapter Thumbs +Text file chapter support
By VideoFanatic in forum Authoring (Blu-ray)Replies: 10Last Post: 1st Feb 2015, 13:49 -
Chapter Points marked in editing phase will not "lock in" for menu creation
By Len Scapoff in forum Authoring (DVD)Replies: 2Last Post: 21st Dec 2014, 03:04 -
Chapter creation problem on DMREZ49
By alexh110 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 11th Jun 2014, 14:35 -
Automatic chapter creation
By medwatt in forum Newbie / General discussionsReplies: 6Last Post: 4th Jun 2014, 20:41
