    Sep 2017
    USA
    I see that Apple now supports HEVC on Sierra. I use IMAC with Apple compressor. I am assuming that if I upgrade, Compressor will have H.265 available as a file compression type.
    However, does the BD player being used to play a BD disk that I author with H.265 need to be able to play this file format ? If so, I believe that all the current BD players will not be able to play a BD disk authored with H.265 ???
    Also, does anyone know if Adobe Encore has any issues with H.265 ??
    Thanks.......
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If you are talking about the June press release on macOS High Sierra (10.13), the upcoming OS version will include support for OS-level HEVC encoding and decoding, including hardware acceleration where available (Skylake, Kaby Lake, Radeon 400).
    I’m sure new presets will be included, taking advantage of HEVC, although I haven’t seen specifics on new version FCP / Compressor.
    The newer UHD Blu-ray players should have some support for HEVC, as HEVC is used for 4K. ‘Regular’ Blu-ray players are only required to deal with H.264 AVC, not H.265 HEVC.
    Encore has been retired for a long time now. End of life; no bug fixes, no new features coming.
    Aug 2006
    Authored Blu-ray discs cannot contain HEVC/H.265 video. The Blu-ray spec only allows AVC/H.264 or MPEG-2 video. You might be able to author a HEVC/H.265 "Blu-ray" with non-compliant software, but no hardware Blu-ray player would play it. Looking at manuals for a few recent Blu-ray players, none decode HEVC, even as media files.
    UHD Blu-ray authoring software doesn't exist in the consumer realm. However some UHD Blu-ray players can play HEVC files burned as data on BD-R. The LG UP970, Samsung BD-J7500, and Samsung UBD-M8500 play HEVC media files. [Edit]The Sony UBP-X800 plays HEVC media files too.
    Mar 2026
    South Bend, Indiana
    In the event that, like me, someone finds this post and decides to purchase a Samsung BD-J7500 in order to play HEVC files... don't. This is incorrect. The J7500 does NOT have an HEVC/h265 codec.
